1972 LT1 intake manifold torque - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    Is the torque for the LT1 aluminum intake manifold the same as the base 350 intake manifold? That is 30 ft-lbs.
    • 3416
    Re: 1972 LT1 intake manifold torque
    Hi Jerry,
    I looked in the 71 Chassis Service Manual and it too indicates 30 ft/lbs. It doesn't differentiate for aluminum manifolds.
    • Jerome P.
      • October 22, 2006
      • 607
      That is what I also found. Thanks for looking and your time. I just wanted a confirmation that I was not overlooking something.
      Thanks Again.
        • 43255
        Thanks Again.
        Jerome------
        Your application did not originally use flanged head bolts but they should have!
        • Jerome P.
          • October 22, 2006
          • 607
          Thanks for the comment, Joe.
          Curious, you comment because the LT1 has an aluminum intake and a flanged head bolt will distribute the pressure more evenly. Correct?
            • 43255
            Jerry------
            Yes, that's part of it. In addition, standard hex head bolts will often "gouge" the area surrounding the bolt holes. There are also some smaller OD washers that can be used with conventional hex head bolts to achieve the same effect as flanged head bolts.
            • Jerome P.
              • October 22, 2006
              • 607
              The original application, I think, had a flat washer. Am I correct?
                • 43255
                Jerome------
                Not that I know of. As far as I know, the standard hex head bolt seated directly on the manifold.
                  • 11677
                  From the upcoming 70-72 JG, with photo references removed:
                  "350 aluminum intake manifolds have no washers under the black-plated hex-head bolts in 1970 and 1971; however, most 1972s have thick flat washers under the bolts that did not have a bracket under them. A few very early 1972s manifolds have been seen without washers. No split-ring locking washers are used in any year. Common headmarkings are C and AL. Often different headmarks appear on the same car."
                  • Jerome P.
                    • October 22, 2006
                    • 607
                    ".... Common headmarkings are C and AL. Often different headmarks appear on the same car."
                    Pat,
                    You mention common head markings. Are there other head markings beside the the "C" and "AL" markings that are not as common to the '72? Or are the head markings strictly limited to "C" and "AL"?
                      • 43255
                      Patrick------
                      That's interesting; I was unaware of that. I guess GM finally got it figured out by 1972 (just before they stopped using aluminum manifolds for several years). They should have asked me. I wonder if 1978-82 Corvettes with aluminum manifolds used the washers? I've never looked.
                      By the way, this was no problem for big blocks. Big blocks always used flanged head bolts for the intake manifold. Small blocks, both cast iron and aluminum manifolds, should have, too.
                        • 11677
                        Pat,
                        It was a production environment - you can never say never, and other headmarks are expected to occur.
                        This is especially true under the engine lift tab or other locations where bolts had more than one purpose.
                          • 43255
                          Patrick------
                          Yes, bolts that were identical with the exception of a difference in length, even a slight difference, often had different manufacturers (and, thus, headmarks).
