Need to locate bearings for 53-62 steering worm gear. - NCRS Discussion Boards
  • Tom P.
    • April 1, 1980
    • 1815
    I KNOW that the bearing on each end of the 53-62 steering shaft worm gear is still available (because aftermarket kits contain the 2 bearings). But I do NOT need to buy a full kit. I just want to locate the bearings (tapered roller bearings).
    Does ANYONE know a brand/part number for these bearings.
    And yes, I have searched and searched the Internet for the bearings. No luck. I have found the caged roller bearings and the seal for the pitman shaft, but I can't locate the roller bearings for the worm gear. Anyone got a part number and manufacturer?
    By the way, the Chevy part number is 261866, haven't been able to cross reference that either.
  • Tom P.
    • April 1, 1980
    • 1815
    Re: Need to locate bearings for 53-62 steering worm gear.
    FOUND 'UM!!!!!!!!!!!!!!!!!
    Chevys of the 40s, I wasn't looking in the right place, and I just accidentally stumbled across them.
    They are a THRUST bearing for the worm gear.
    Thanks for the efforts!!!
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11345
      Tom, If it doesn't work out, I have some good used originals you can have. I rebuilt a box a few years ago with the new complete kit and used the new worm thrust bearings but the originals were not damaged so I saved them.
      Rich
        • 43255
        Tom-------
        • Tom P.
          • April 1, 1980
          • 1815
          Thanks everyone.
