66 327 inspection cover bolts - NCRS Discussion Boards
  • Brian K.
    • May 31, 2004
    • 358
    Okay the judging manual says 7/16 recessed hex head bolts, but some of the venders sell the slotted screw type for 1966. My clutch had been changed so not sure if mine are correct (hex head) and the judging guide has been wrong so I just want to clarify what's correct.
    • January 31, 1988
    • 43194
    Re: 66 327 inspection cover bolts
    Brian------
    Hex head.
    • Brian K.
      • May 31, 2004
      • 358
      Thanks again JOE for the reassurance, I can sleep peacefully tonight.
      • Ralph E.
        • January 31, 2002
        • 905
        Please excuse this tag to this post.
        Can the inspection cover be removed with the oil filter in place.
        The small bolt near the canister or screw-on filter seems very tight. Can it be removed?
        • Larry M.
          • December 31, 2001
          • 537
          So this thread is about two years old but I have the same question. The 63/64 Judging guide says recessed hex with E or L. Most vendors say pan head for 63-66 and hex for 67 but always hex for powerglide...they likely learned that from somewhere. Joe says hex for 66 above but I wonder if we have given this proper attention.
          • Gary B.
            • January 31, 1997
            • 6988
            Brian,
            The original inspection cover bolts on my July build date '66 are indented hex head with a captured external tooth washer and with either L head-mark or a wavy flag head-mark.
            Gary
              • January 31, 1988
              • 43194
              Originally posted by Gary Beaupre (28818)
              Brian,
              Gary
              Gary------
              GM #3817006. By the way, this part number dates back to 1962. That, of course, does not mean it was used since then for the oil pan and timing cover applications. However, it does mean that it was available for use for those applications since that time.
              • Larry M.
                • December 31, 2001
                • 537
                A July 66 car might be a lot like a 67 on this. This would have been an engine plant change and not a St. Louis change. The part number to 62 would be necessary to support powerglides. Hopefully some others like Alan Drake will weigh in.
                • Gary B.
                  • January 31, 1997
                  • 6988
                  Gary------
                  Joe,
                  Is GM 3817006 documented to have a captured external tooth washer?
                  Gary
                    • January 31, 1988
                    • 43194
                    Larry------
                    Not necessarily. There are many other bolt/washer configurations that could have been used for Powerglides.
                      • January 31, 1988
                      • 43194
                      Joe,
                      Gary
                      Gary-------
                      Yes. The GM #3817006 is the exact configuration seen on oil pans and timing cover bolts and also other applications like water pump backing plates, etc.).
                      When it was discontinued from SERVICE more than 20 years ago, it was replaced by separate bolt and washer. The bolt was a trimmed ("non-indented") head of GM #180016 and external tooth lock washer of GM #121753.
                      • Richard G.
                        • July 31, 1984
                        • 1715
                        Here are some pictures;
                        Having done many transmissions these bolts are typical for 60 gm stuff not only the Corvette.
                          • January 31, 1988
                          • 43194
                          Richard------
                          If this bolt is from prior to about 1962, then it must be some predecessor part number to the GM #3817006. The 3817006 couldn't have existed prior to about 1962. I also note that it appears that this bolt is black phosphate-finished. If so, that could imply it's of a different and possibly earlier part number since I believe the 3817006 was always a zinc plated part.
                          Actually, I've always wondered why the 3817006 was zinc plated. Virtually all of the applications I know of for these bolts had them painted after installation (e.g. timing cover, flywheel cover, oil pan). Usually, GM would not specify any plated finish for fasteners to be subsequently painted. I suppose the purpose was economy since fasteners to be painted did not really need to be first plated. However, it may be that there were enough non-painted applications for the bolt that they may have decided plating was in order.
                          • Richard G.
                            • July 31, 1984
                            • 1715
                            Joe;
                            The 1/4 bolt in the picture should be a Dec 62 bolt.
                            Thanks for sharing your knowledge on fasteners.
                            Many of the nuances of the larger items are fairly well known.
                            The fastener details are still being dug up!
                            Thank you.
                            Rick
                            • Marco H.
                              • February 28, 2002
                              • 218
                              Gents,
                              There have been plenty of original - unrestored small block cars observed with slotted screws and external star washer to secure the clutch cover. From '63 through beginning '66. I have not seen an unrestored 396/427 with slotted screws yet.
                              Marco
