66 327 block holes - NCRS Discussion Boards
66 327 block holes
  • Brian K.
    • May 31, 2004
    • 358
    66 327 block holes
    Did GM put anything in either of these 2 threaded holes on the front of a 1966 327 engine block?
    • January 31, 1988
    • 43195
    Re: 66 327 block holes
    Brian------
    You bet they did! The upper tapping MUST have a short 3/8-16 bolt, installed with sealer. It goes through to the fuel pump push rod channel and will leak oil if it's not plugged with a bolt.
    The lower tapping had no bolt installed.
    • Brian K.
      • May 31, 2004
      • 358
      Thanks Joe, any idea what it looks like recessed head?
        • January 31, 1988
        • 43195
        Brian-----
        No, it was a trimmed (i.e. "non-indented head") bolt. It was about 3/8" to 1/2" in length.
        • Brian K.
          • May 31, 2004
          • 358
          Thanks again Joe.
          • Domenic T.
            • January 28, 2010
            • 2452
            Brian,
            To add to what Joe said, those were used as engine mount holes on early C2 cars. The hole that needs to be plugged is for fuel pump installation. It holds the push rod up using a longer bolt so the arm on the pump can be placed under it. Using the wrong length bolt will damage the pump push rod.
            Dom
              • January 31, 1988
              • 43195
              Originally posted by Domenic Tallarita (51287)
              Brian,
              Dom
              Dom------
              The mounting holes were not used for C2 Corvettes. They were, however, used for C1 Corvettes and passenger cars through 1957.
              • Domenic T.
                • January 28, 2010
                • 2452
                Joe,
                Thanks for catching that, I don't know why I said C2 instead of C1.
                Dom
