'66 327 / 350 HP Valve covers - NCRS Discussion Boards
  • Steve Z.
    • July 31, 1993
    • 68
    I just finished glass beading my aluminum valve covers. They now look much better but now have a flat gray color is there any way I can get them back to the same type of finish they were originally ?
    Steve
  • Gene M.
    • April 1, 1985
    • 4232
    Re: '66 327 / 350 HP Valve covers
    Steve,
    Glass beading if done with anything more than dust and at more than 40 lbs will destroy the the die cast surface skin. Sure they look nice but not correct. I suggest you let them sit in the acid rain to tone back the appearance you are left with. The flat gray you speak of sounds like it was too aggressive on these parts.
    • Gary B.
      • February 1, 1997
      • 7024
      Steve,
      If Gene's idea doesn't produce the look you're after, you could talk to John DeGregory who has restored hundreds of AL valve covers. John posts on the Discussion Board (DB) and you could contact him via his DB profile.
      Gary
        • 43222
        Originally posted by Gary Beaupre (28818)
        Steve,
        Gary
        Gary------
        I think John's method is that he soaks the valve covers overnight in Sicilian-style marinara sauce. Then, he sautes them in imported olive oil. There; I've said it----his secret is out.
        • Gary B.
          • February 1, 1997
          • 7024
          Gary------
          Joe,
          I bet John's secret ingredient is the non-olive oil additive that the Italians love to use to extend their pure, extra-virgin olive oil.
          Gary
          • Robert R.
            • May 31, 1975
            • 358
            Canola oil with a touch of cloriform ?
            • Bill W.
              • November 1, 1977
              • 402
              Steve,
              There was an article in the RESTORER years ago that dealt with restoring aluminum valve covers, unfortunately I can't find it. I seem to remember scrubbing them with an SOS pad (lightly) then spraying dull aluminum paint on the valve cover and finishing the process with a paint brush dipped in lacquer thinner that has dull aluminum paint in it. Wish I could find the article but it's past my bed time. If the above does not work contact Joe Lucia, he will sell you an NOS set of valve covers. Joe sells stuff ALL the time! Bill
              • Steve Z.
                • July 31, 1993
                • 68
                Thanks everyone,
                Steve
                • Bill M.
                  • 1328
                  anyone know how much it costs to restore?
                  • Steve Z.
                    • July 31, 1993
                    • 68
                    I just got a reply from John DeGregory he gets $150.00.....
                    Steve
                    • Domenic T.
                      • January 29, 2010
                      • 2452
                      I used a mild Stainless brush after glass bead and it brought back the sheen.
                      Dom
                      • John D.
                        • December 1, 1979
                        • 5507
                        Gary------
                        Joe, I only use EVOO. No cheap olive oil.
                        Italian story. Growing up my family never use EVOO. I don't even know if it was available.
                        Thanks for the plug guys but at the moment my pal JD is absolutely buried in work. Getting read for Corvette Carlisle now. Oops. Getting ready for customers jobs at BG first.
                        • Brian K.
                          • May 31, 2004
                          • 358
                          I've had good luck with a product called "Nice and Easy Aluminum cleaner" found at True-Value hardware, gives that nice washed look.
                          • Donald H.
                            • November 2, 2009
                            • 2580
                            If you decide to have them reworked by a restorer and JD is to backloged, call Fred Hudson 405-620-2748. Both do very nice work. JD did my valve covers and they look great. Fred did my aluminum intake and it also looks great. Fred's Driveline ad is in the Services & Miscellaneous section.
                            Don Harris
                            • Steve Z.
                              • July 31, 1993
                              • 68
                              Thanks everyone for the suggestions.....
                              Steve
