73 Vert drivers door Blue VIN label - NCRS Discussion Boards
  • Tom H.
    Infrequent User
    • May 31, 1990
    • 6
    I need to replace the blue VIN decal on the drivers door of my 1973 convertible. Options include 350 cu in, AC, Automatic, Power Windows, Power Brakes & hardtop. If anyone has these options on their '73, I need the entire vehicle weight specs off of your label listed just underneath "Mfg By General Motors Corp". Thank you. Tom Harmon #17320.
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 73 Vert drivers door Blue VIN label
    To open up the field to more responses, I would think the L48 would weigh the same.
    • Tom H.
      Infrequent User
      • May 31, 1990
      • 6
      thanks Russ. I will change to 350.
      • Jimmy P.
        • June 24, 2014
        • 1696
        Hi Tom,
        I would be happy to give you label numbers from my 73 convertible but unfortunately it doesn't have the same options as yours. However, I've attached a couple pages of specifics for the 73 and what each item weighs. It might be easier to get the data from someone who has the same options as you do though. Hopefully, someone will help you out.
        Good Luck,
        Jimmy
        Jimmy
        1973 Convertible
        L48,M20,N40
        Mille Miglia Red/Oxblood
          • 3416
          Hi Jimmy,
          The info on your sheets is interesting.
          Thanks for posting them!
          • Robert R.
            • May 31, 1975
            • 358
            Hi Tom
            The sheets that Jim posted may affect the weights you are looking for. Does your car have the base engine or L82? Also is your AM FM radio a stereo? Both options have extra weight associated. If it is a base engine and stereo, I can offer the numbers listed on mine as the other options you listed are the same.
            Bob
            • Harmon C.
              • August 31, 1994
              • 3228
              I had an article in the Restorer in the 90's on 73 corvette weights that may help. The numbers are also in the GM parts manual.
              Lyle
              • Jimmy P.
                • June 24, 2014
                • 1696
                Originally posted by Robert Ricchio (599)
                Hi Tom
                Bob
                Hi Robert,
                I'm pretty sure he originally listed that he has an L82. The second page of my above attachments does have the added weights for the different motors and all the options. Or at least I thought that's what those numbers are. I guess you add those to the base weight All those numbers came from the 73 corvette Factory specifications Manual from GM.
                Thanks ,
                Jimmy
                Jimmy
                1973 Convertible
                L48,M20,N40
                • Robert R.
                  • May 31, 1975
                  • 358
                  Hi Jim
                  The list you have IS how the weights would be calculated for the car. When I read the OP post, their was no reference to the optional engine. And the stereo radio adds 4 lbs due to the bigger heat sink.
                  We are on the same page, just looking for the details to help him.
                  Bob
                  • Tom H.
                    Infrequent User
                    • May 31, 1990
                    • 6
                    Thanks Jimmy. Great info.
                    • Tom H.
                      Infrequent User
                      • May 31, 1990
                      • 6
                      Hi Bob,
                      It is an L82, AM FM Stereo. Thank you.
                      • Robert R.
                        • May 31, 1975
                        • 358
                        Tom,
                        Hopefully you saw the pm I sent you. Add the L82 option weights and you should have your total for the three number sets.
                        • Tom H.
                          Infrequent User
                          • May 31, 1990
                          • 6
                          Thanks to all of you for your help. I have enough information to calculate the GVW. Much Appreciated !
                          • Clarence B.
                            Infrequent User
                            • March 30, 2015
                            • 27
                            Tom:
                            Here is the GM vehicle Information Kit for the 73 C3. Has the above listed info--and other specification information that is interesting to read.
                            https://www.gmheritagecenter.com/docs/gm-heritage-archive/vehicle-information-kits/Corvette/1973-Chevrolet-Corvette.pdf
                            GM Heritage is committed to preserving the rich history of General Motors brands while providing a foundation for continued innovation into the future.
                            • Tom H.
                              Infrequent User
                              • May 31, 1990
                              • 6
                              Thanks Clarence. I will check it out.
