C3 Ignition switch - NCRS Discussion Boards
C3 Ignition switch
  • Wayne M.
    • March 1, 1990
    • 3
    C3 Ignition switch
    I believe my 1970 350/350 has an ignition switch problem. When I turn the ignition switch to the start position, nothing happens and my ammeter shows a "dead short" (needle pegs to max discharge). My battery is fully charged. Could this problem be anything other than a ignition switch problem? If not, does anyone have a quick and easy way to test the ignition switch without taking it out of the car?
    • 15630
    Re: C3 Ignition switch
    It could be the starter, and that is a devil of a lot easier to change than the ignition switch. If you had a clamp-on ammeter you could determine if the issue was the starter. If the ammeter showed a large current draw to the + cable to the starter = bad starter.
    • Wayne M.
      • March 1, 1990
      • 3
      I just put in a "rebuilt" started from Chicago Corvette (which was supposedly completely tested) before I bought it. Unfortunately I did not test it before I put it in the car. Do you still think that could be the problem?
        • 43272
        Wayne------
        Definite possibility. Do the current draw test that Terry suggested.
