Fan Clutch - NCRS Discussion Boards
Fan Clutch
  • Frank K.
    • January 1, 2000
    • 319
    Fan Clutch
    What is the part number for a fan clutch (coil type) !977 car late Vin L-82 motor? Who makes a replacement?
    • 43248
    Re: Fan Clutch
    Frank------
    Several could have been used. GM #343720 or GM #460742. If the car has C-60, then it's likely GM #343721. However, I don't think you find any of these numbers on the clutch.
    The 343720 and 460762 are discontinued and replaced by GM #88961763 which is also now discontinued.
    The 343721 is discontinued and replaced by GM #88961768. The latter is the fan clutch that I recommend for your application whether or not you have C-60. If replacing the 343721 it will appear virtually identical. If replacing one of the non-AC clutches, it will appear considerably different. However, the 88961768 is the best performing fan clutch EVER installed on a Corvette. Period. However, it can be a bit noisy but it cools.
    I still suggest that you post a photo of what you currently have.
