Fan Clutch - NCRS Discussion Boards
Fan Clutch
  • Frank K.
    • January 1, 2000
    • 319
    Fan Clutch
    How do you adjust the coil type fan clutch? 77 car I can not see the diagram in the NCRS book Will the adjustment drop the temperature in my engine at high speeds?Is there fluid in this unit?
    • 43247
    Re: Fan Clutch
    Frank------
    Which fan clutch do you have? A photo will help us identify it.
    Generally, fan clutches do not provide much of the cooling when the car is traveling along at speed. The main purpose of fan clutches is to provide airflow when the car is at low speed or idling.
    Yes, if it's a thermal type clutch (which all OEM clutches are), there is silicone fluid in it.
    • Frank K.
      • January 1, 2000
      • 319
      Re: Fan Clutch
      I have a thermostatic coil according to picture of cooling system in NCRS book.
      • Jack M.
        • March 1, 1991
        • 1181
        Re: Fan Clutch
        I'm not sure if this old article will help: CLICK HERE
          • 43247
          Re: Fan Clutch
          Frank------
          ALL 1977 Corvettes used a fan clutch with a coil type thermostat. However, there were at least 2 different clutches used. In addition, how do you know that the clutch on the car now is original and not an aftermarket replacement?
          • Frank K.
            • January 1, 2000
            • 319
            Re: Fan Clutch
            The fan clutch is original to the optional L-82 mtr with 4 speed trany.
              • 43247
              Re: Fan Clutch
              Frank-------
              Does the car have C-60 or VO1 HD cooling. If so, you should have a GM #343721 fan clutch which is an excellent fan clutch and the predecessor to the GM #88961768 which I recommend.
              Does it look like this (except with just a 4 hole hub, not the 8 hole pictured):
              • Frank K.
                • January 1, 2000
                • 319
                Re: Fan Clutch
                Yes mounting 4 hole
                • Leif A.
                  • August 31, 1997
                  • 3645
                  Re: Fan Clutch
                  Frank,
                  Depending on the age of the clutch, re-positioning the end of the coil spring 1/2-turn counter-clockwise (as viewed from the front) may cause it to engage about 15*F sooner.
                  Leif
                  • Frank K.
                    • January 1, 2000
                    • 319
                    Re: Fan Clutch
                    Fan cut out type Thermo-modulated viscous-clutch
                      • 43247
                      Re: Fan Clutch
                      Originally posted by Leif Anderson (29632)
                      Frank,
                      Leif------
                      I don't think that can be done with this configuration fan clutch.
                        • 43247
                        Re: Fan Clutch
                        Yes mounting 4 hole
                        Frank------
                        Yes, but does your clutch otherwise appear exactly like the one I pictured?
                        Also, keep in mind that if yours is original to the car, it could be worn out. These things are not "forever" pieces.
                        • Frank K.
                          • January 1, 2000
                          • 319
                          Re: Fan Clutch
                          Exactly also C60
