1954 fuel pump bubbling. - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 500
    After a good run yesterday I noticed my pump was bubbling and forcing a small amount of gas out the bowl. In my case after the pump was rebuilt it was delivering about 8 psi which overpowered the carbs. They're supposed to run under 5 psi. I was forced to put a 4 # regulator on it. Is this a common issue with these pumps? How does the pump relieve the pressure? Any thoughts?? Thanks.
  • Guy M.
    • November 1, 1993
    • 500
    Re: 1954 fuel pump bubbling.
    Another question for the fuel gurus, Can the pump maintain a 7 psi pressure between itself and the 4 psi regulator at rest? Seems like fuel is squeezing out the diaphragm gasket at rest or maybe as its running. the screws are tight. I don't know of a way to relieve the pressure is there? Thanks
    • Chris S.
      • January 1, 2000
      • 1067
      something is not correct - the pump should put out 4 psi
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Guy M.
        • November 1, 1993
        • 500
        Thanks Chris, Ill have to check the pressure again. Took 300 miles for it to show itself.
