Looking at buying a '72 LT-1 that has had a recent engine rebuild. The owner chose to replace the solid lifters with hydraulic lifters so as to avoid having to adjust the valves. The car comes with the original lifters and cam. I assume this change would have no bearing on the value of the vehicle based on the fact that the original parts are included?
As part of the engine rebuild the cylinders were bored .30 over...any impact on the value of the car?
Also wanted to confirm that an M-20 transmission with 4.11 rear end was a possibility on an LT-1 as it appears to be equipped as such.
Ron
Ron
