SB Water Pump 3782608 - NCRS Discussion Boards
  • Michael G.
    • January 1, 1997
    • 1251
    Helping a acquaintance with his '68 327 and wanted to validate the '608' water pump was used on the engine.....Thanks.
  • Larry M.
    • January 1, 1992
    • 2701
    Re: SB Water Pump 3782608
    Yes...............for the 300 HP engine.
    Larry
      • 43248
      Larry
      Larry and Michael-----
      The 3872608 waterpump casting was used for ALL 1968 Corvette small blocks----300 HP and L-79. External bypass type waterpumps for L-79 ended with the 1967 model year. External bypass for Corvette small blocks was never to be seen again after 1967. However, 1972-82 Corvette small blocks did use a waterpump with provisions for external bypass but it was unused and plugged.
