Help from 66 owners with VIN below 5300, St Louis body, underbody exhaust - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7053
    For the birdcage bracket research project that Don Harris and I are doing, we’re looking for one or more owners of 66s with a VIN below 5300, St Louis body, and underbody exhaust. Does anyone know of any such owners out there who could take a peak at their rocker panel brackets? We would like to know the number of metal brackets (one on side of the car) from the bird cage door sill that are used to attach the rocker panel.
    Gary
  • Tom D.
    • September 30, 1981
    • 2137
    Re: Help from 66 owners with VIN below 5300, St Louis body, underbody exhaust
    I can look at 2999.
    Tom D.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Gary B.
      • February 1, 1997
      • 7053
      Tom,
      Thanks. Also if you can report the Trim Tag date code and confirm it's a St Louis body.
      Gary
      • Patrick C.
        • January 16, 2013
        • 327
        4070 vin, late oct 65 build, stl body
        • Gary B.
          • February 1, 1997
          • 7053
          Patrick,
          Does your car have 6 brackets per side from the bird cage door sill that the rocker panel attaches to? Or 3? And it a coupe? Or a roadster?
          Gary
          • Patrick C.
            • January 16, 2013
            • 327
            Originally posted by Gary Beaupre (28818)
            Patrick,
            Gary
            Roadster
            • Ronald M.
              • August 31, 1999
              • 44
              #5139, left St. Louis with underbody exhaust, six metal brackets per side.
              Ron
              '66 convertible
              Ron Myers
              '66 Roadster
              • Donald H.
                • November 2, 2009
                • 2586
                Ron
                '66 convertible
                Ron,
                Couod you give us the body build date off your trim tag please?
                Don Harris
                Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
                • Ronald M.
                  • August 31, 1999
                  • 44
                  Originally posted by Donald Harris (51003)
                  Ron,
                  Could you give us the body build date off your trim tag please?
                  Don, the body build date is C8, with a still visible, hand scrawled '30' on each door.
                  Ron Myers
                  '66 Roadster
                  • Tom D.
                    • 2137
                    Originally posted by Tom Dingman (4889)
                    I can look at 2999.
                    Tom D.
                    Guys: Thanks for this effort. My 1966 Convertible was made two or three days before my 21st birthday. The well published photo of the shriner's Corvette delivery in St. Louis, with the unfinished arch in the background, was taken only two days after #2999 was finished.
                    B13 is the tag date, and the body is S968. It has a total of 12 brackets.
                    When I moved to WNY, I took note of this car and met the first owner. When I bought it ten years later, It had been modified so much that I didn't know (until I got it home) that it was the same car. Photo one shows a Cadillac color on the orig. Trophy Blue.
                    Michigan Chapter
                    Tom Dingman
                    • Gary B.
                      • February 1, 1997
                      • 7053
                      Tom,
                      Just to be clear, the B13 trim tag car is yours, not VIN 2999.
                      Gary
                      • Tom D.
                        • 2137
                        The B13 trim tag is on my car, which is number 2999.
                        Michigan Chapter
                        Tom Dingman
                        • Tom B.
                          • March 1, 2002
                          • 140
                          Serial #4840 St Louis Coupe 6 brackets S867
                          • Gary B.
                            • February 1, 1997
                            • 7053
                            Tom,
                            Thanks. Can you also tell me the alphanumeric Trim Tag date code? We'll eventually present the date using the Trim Tag code, rather than VIN.
                            Gary
                            • Tom D.
                              • 2137
                              B13, as stated above.
                              Michigan Chapter
                              Tom Dingman
