67 bb a/c - NCRS Discussion Boards
67 bb a/c
  • Jeff S.
    • February 1, 2005
    • 72
    67 bb a/c
    I am looking for the correct clocking position for the POA valve on a 67 big block 390 HP. Thank you for any help. Jeff A picture would really help out, the AIM does not show the proper positioning of the lines and the valves.
  • Larry M.
    • January 1, 1992
    • 2701
    Re: 67 bb a/c
    Jeff:
    First thing is you need to make certain that you have the correct POA valve. Check the part numbers to be sure against the AIM. There are three (3) different configurations, each with different clockings of the side fittings.
    Second, the oil return line and the evaporator core equalization line should help correctly position the POA. If you have the correct POA for your car, these auxiliary lines will not allow for too many positions without running out of tubing length. Also if I remember correctly, the remaining Schrader connection on the POA for hooking up your gages should point into the passenger inner fender and require a special 90 degree attachment connector to allow the manifold gage hose to be hooked up. I know I had to purchase this 90 degree connector to allow me to help a few other 1967 BB Corvette owners with their AC.
    Hopefully someone will help and post a picture for you. I don't have any..................as my 1967 factory AC car is a small block.
    Larry
    EDIT: These POA valves are known for being a problem...........and often sticking closed or almost closed when they should be open. There are simple test procedures you can do to check for proper operation. A few special fittings and a AC gage manifold set are required along with an air supply. I have the procedure, but it is also available on-line. Also if you are NOT going to use R12, then a POA valve adjustment is also required. I do not know your situation, so I cannot comment/help much unless you ask and provide additional info.
    • Keith B.
      • September 15, 2014
      • 1592
      Re: 67 bb a/c
      • Jeff S.
        • February 1, 2005
        • 72
        Re: 67 bb a/c
        Larry Thank you for the info, I will check the part number to the AIM, I believe it to be an aftermarket item. Jeff
        • Jeff S.
          • February 1, 2005
          • 72
          Re: 67 bb a/c
          Keith, Great picture thank you.Do you know if that is the correct POA according to the AIM ? Jeff
          • Keith B.
            • 1592
            Re: 67 bb a/c
            That POA valve was the correct NOS service part number for 67 cars. Not sure on the part number. It judged well at the Charlotte regional last year
            • Jeff S.
              • February 1, 2005
              • 72
              Re: 67 bb a/c
              Keith, can you send me a picture that would be a little closer, I do not have the bracket that holds the POA to the evaporator case ?
              • Larry M.
                • January 1, 1992
                • 2701
                Re: 67 bb a/c
                I just checked my files, and the 1967 AIM has a part number that is not available in service. It is GM #5910602. AIM indicates it is the same for SB and BB cars. The GM Parts book shows the replacement valve at DELCO # 15-51 and GM # 5910593.
                Larry
                • Larry M.
                  • January 1, 1992
                  • 2701
                  Re: 67 bb a/c
                  LICS may have this bracket. See their AC Section 35 for details. My old LICS catalog shows this bracket. If not there are a few other sources we can try.
                  Larry
                  #35-53A and B is the bracket and clamp.
                  • Keith B.
                    • 1592
                    Re: 67 bb a/c
                    The car is at my fathers garage as its his car. Next time I'm up I will take more pictures for you
                    • Greg H.
                      • 105
                      Re: 67 bb a/c
                      Hi Jeff,
                      This is my 67 small block assembly. Hope this helps.
                      Greg
                      • Jeff S.
                        • February 1, 2005
                        • 72
                        Re: 67 bb a/c
                        Greg Thank you that helps a lot. ty ty ty
