1963 Corvette Signal Flasher - NCRS Discussion Boards
  • Lawrence E.
    • November 7, 2013
    • 23
    Hello
    I have a 63 April car with 327/340 carb engine. I'm looking to track down a Signal Flasher. What is the correct number/stamp that should be on the
    Signal Flasher for a 63 April car? Is it the image below or a different stamp?
    thanks, Lawrence
  • David L.
    • July 31, 1980
    • 3310
    Re: 1963 Corvette Signal Flasher
    I have seen both the Signal Stat ZN332 and the Signal Stat 143 flasher in GM boxes with the same part number 3758682.
    My 63 parts catalog lists AP373V as part # 3758682. I think that the consensus is AP373V and Signal Stat 143.
    Also, the 2 links below might help.
    Dave
    https://www.forums.ncrs.org/showthre...ht=tung+ap373v
    https://www.forums.ncrs.org/showthre...signal-flasher
    • Bob R.
      • June 30, 2002
      • 1595
      The 142 you have a photo of would be for a car with backup lights. Most likely you need either a Tung Sol AP373V or Signal Sat 143, both were used.
      • Lawrence E.
        • November 7, 2013
        • 23
        Thanks for all the help guys ... I guess I should have looked closer at my Tech Judging Manual but nonetheless I've ordered two 143 Signal Stats off eBay. Fingers crossed they're in good functioning condition ...
        Lawrence
