Part # question - NCRS Discussion Boards
Part # question
  • Jeff C.
    • September 30, 1997
    • 233
    Part # question
    I have rear end which has a casting # of 3876476-N which is a late 65 all 66 casting. The question is the stamp on it is AK 420 65?
    The book says there should be a letter for the assy plant.
    Jeff
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Part # question
    Jeff
    Jeff --- I'm surprised that nobody has replied in the 36 hours since you've posted. Probably because carrier casting numbers and dates are not judged. I used to own a '65 convertible VIN 16524 with differential assembly code AM_4_2_65, so probably very close you yours. Which book are you referring to that calls for a plant code ?
    I have two late July '65 assy, BB diffs ( FA 7 15 65, and FB 7 21 65) and they are both "...476" castings and neither has the "W" (Warren MI plant) identifier. . Neither does an AU 5 17 67 carrier I use as a door stop . But an October '68 carrier I have does have the W suffix (2AL 10 26 W), in a ...143 casting.
