1963 heater capacitor location picture - NCRS Discussion Boards
  • John S.
    Infrequent User
    • April 30, 2006
    • 9
    I have a 1963 with an AM/FM radio. I have looked at the Assembly Manual but I am still not sure of how and where the heater capacitor is mounted. Could anyone please send a picture of an installed capacitor on the heater motor.
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 1963 heater capacitor location picture
    Early cars did not have a heater blower capacitor same on other 'hang on' items, not sure at what point capacitor was added. Others will chime in. What is the build date of your car?
    • John S.
      Infrequent User
      • April 30, 2006
      • 9
      Build date is 2nd week of May 1963 and I think all AM/FM cars had a capacitor on the heater blower.
      • Michael G.
        • January 1, 1997
        • 1251
        The capacitor function only helps on the AM side of the radio as I understand it regardless of a car having AM/FM. Unsure when the capacitor was added to diminish heater blower noise.
        • Loren L.
          • April 30, 1976
          • 4104
          It probably occurred at the time of the AM to AM-FM changeover, same as the added clip to the tach cable ground.
          • Harry S.
            • July 31, 2002
            • 5330
            The switch was around VIN number 11700.
            • Bob R.
              • June 30, 2002
              • 1595
              If you have an AIM look under the section on the AM FM radio and it will show all of the capacitors. The blower motor capcitor is attached to the wiring at the blower motor
              • Richard G.
                • July 31, 1984
                • 1718
                Date coded Date coded 64B. Cant confirm if it's correct or not but may give you some ideas.
                Seems to be missing the undercoating so likely the motor is a replacement.
                • Michael G.
                  • January 1, 1997
                  • 1251
                  Motor should have date embossed on flange.
                  • John S.
                    Infrequent User
                    • April 30, 2006
                    • 9
                    Thanks, have taken care of it.
