Flight scoring a non-original part - NCRS Discussion Boards
This topic is closed.
+ More Options
Posts
  • David H.
    • June 30, 2001
    • 1560
    Re: Flight scoring a non-original part
    Originally posted by Frank Dreano (48332)
    It just shows the myth of the 'objective standards' the NCRS touts so heavily....
    Not sure what you mean by "... myth of the 'objective standards'.....". I don"t think anyone posting on this thread disagreed with the OP - seems like pretty consistent judging to me. All the more reason for owners to become familiar with the judging process.
    • Michael J.
      • January 27, 2009
      • 7167
      +1 CDCIF was made for consistency, and it works most of the time.
      • Mark E.
        • April 1, 1993
        • 4607
        #18
        Originally posted by Michael Ward (29001)
        The 100% deduct idea makes no sense. It would result in all service replacement parts taking a full deduct irrespective of their resemblance to original parts.
        Never heard the full deduct logic before
        It was a Q-Jet from a '69 350/350 engine, not a service replacement.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
          • 43282
          #19
          Mark------
          The 1969 L-46 Q-Jet, GM #7029207, was used as a SERVICE replacement for all 1968-69 Corvette Q-Jet applications for many years.
            • 11692
            #20
            The 69 350/350 Qjet was actually catalogued as the service replacement carb for many, many years; 20 or more? So, in a way, it was a service replacement. My 1971 came with the same carb, but dated from 1976 (or 86, possibly).
            Despite that, I think you scored it correctly. Joe C gives a reasonable argument to score it even better, but since 69-74 (or so) Chevrolet-destined Qjets all look very much the same, the number itself takes on quite a bit of importance.
            Patrick
            • Michael W.
              • April 1, 1997
              • 4290
              #21
              As others have said, that part number was used as service replacement- but this brings up a point.
              Judges don't typically have access to lists of GM service replacement part numbers. As such, it would be difficult to say that a carb was NOT a GM service replacement carb based on part number alone.
              • Mark E.
                • April 1, 1993
                • 4607
                #22
                This example does highlight how variation occurs when judging configuration. Some suggested 100% deduction, while Joe C. made a good argument that the judging guidelines specify a partial deduction.
                Maybe a standard deduction can be specified for: a service replacement PN; no number (I have a Q-Jet with no PN stamped); an incorrect number but appropriate for part interchange; some other number.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Harry S.
                  • July 31, 2002
                  • 5344
                  #23
                  What is the difference between a part number and a logo. They are both part of the configuration. If the part appears to be a corvette part then CDCIF the part. If the part number is missing or incorrect it's the same as a C2 outside mirror not having a bowtie logo. You take a 20% deduction. On the mirror, if the date is missing now your at 40%.
                    • 43282
                    #24
                    Mark-------
                    A Q-Jet without a part number indicates it had the float bowl assembly replaced with a SERVICE float bowl. SERVICE float bowl assemblies have no stamped part number. They are, in effect, a "wild card". Theoretically, they could be stamped with any part number, including rare Q-Jet part numbers that used that same float bowl assembly.
                    • Joe C.
                      • August 31, 1999
                      • 4598
                      #25
                      The concept of "all or nothing" within a CDCIF category will be addressed by the higher ups. It was brought to their attention as being important and their input/clarification is required.
                      Obviously "date" is an all or nothing category, indisputably IMHO. The rest, to varying degrees, should accrue deductions proportionally.
                      • Mark E.
                        • April 1, 1993
                        • 4607
                        #26
                        Harry- are you suggesting only two choices for configuration deductions- zero or 100%?
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Harry S.
                          • July 31, 2002
                          • 5344
                          #27
                          Mark, using CDCIF, each part is worth 20%
                          Configuration - 20%
                          Date - 20%
                          Completeness - 20%
                          Installation - 20%
                          Finish - 20%
                          If it's a 10 point item and the configuration is the only thing wrong it's a 2 point deduction. Where do you get the 100% from?
                          To ensure consistence of judging these are the rules we must follow.
                          • Joe C.
                            • August 31, 1999
                            • 4598
                            #28
                            Configuration - 20%
                            Date - 20%
                            Completeness - 20%
                            Installation - 20%
                            Finish - 20%
                            It's obvious that Mark is saying the same thing that I am.
                            I think that you're just being disingenuous.
                            • Harry S.
                              • July 31, 2002
                              • 5344
                              #29
                              Joe and Mark, I don't know what else to say. This is the judging process we follow and it has been for years. The configuration is either correct or not, not almost correct or close to correct. If it does not appear to be exactly correct you get a 20% deduction.
                              Don, please close this thread!
                              • Don H.
                                Moderator
                                • June 16, 2009
                                • 2282
                                #30
                                thread closed
