Brake Proportioning Valve - Date Coded ?? - NCRS Discussion Boards
  • John S.
    • June 15, 2015
    • 507
    As I continue to clean up and document everything I can on my '73, I've come across and interesting one. Not sure if this has been documented or not. From the attached photos and the "73 AIM, I've come up with the following:
    Part Number 3980797
    Patent Numbers 3369090 and 3374322
    And what I believe could be a date code of 2-227 (Aug, 14th, 1972 ) ??
    This falls in line with several other Julian date codes I have found plus it would be legit for my Dec 13th 1972 car.
    Has anyone else documented or seen this before ??
    1973 L82 M21 4 Speed, very original and well documented driver/survivor
    NW Chapter Member, 2016 Bend Regional Top Flight
    73/74 TIM&JG 3rd Edition Revision Team Member
    • 43277
    Re: Brake Proportioning Valve - Date Coded ??
    Part Number 3980797
    John------
    This is not a proportioning valve although it's often incorrectly referred to as such. This part is called a "brake fluid distribution block and brake warning light switch". It has no proportioning function, at all. The only Corvettes that ever had a true proportioning valve were 1966-68 with J-56.
    1978-82 had a COMBINATION valve which included brake fluid distribution, warning light, and fixed-rate proportioning functions.
    • John S.
      • June 15, 2015
      • 507
      Joe - thanks for the update on the description. Any thoughts on the possible date code ??
      John
      • Mike E.
        • February 28, 1975
        • 5141
        This dating is included in the upcoming 70-72 JG. You have decoded it correctly--it is a Julian date.
          • 3418
          Hi John,
          I wonder if we're going to begin looking for re-stamps and the block's surface finish?
          • John S.
            • June 15, 2015
            • 507
            Alan, probably......... With every noted stamping there is certainly a chance for restamp. I note your surface finish has the same radial lines as mine does. My stamping does appear to be a double hit. There's a faint 2-227 behind the visible one. Thanks for the pic and your reply.
            Also thanks to Mike for the date code reply. We'll have to add that one to our list of '73-'74 JG updates.
