1966 427 Rear Main Seal Leak - NCRS Discussion Boards
  • John M.
    • May 31, 1983
    • 56
    All,
    My 66 BB has the dreaded rear main seal leak. I have replaced the seal a few times over the years, but have not been able to fix the issue. I have never removed the engine for a rebuild, thus my efforts have been "engine in" only. Should I assume I have a groove in the crank shaft causing the seal to leak? Any other thoughts would be appreciated.
    John
    • 43289
    Re: 1966 427 Rear Main Seal Leak
    Originally posted by John Means (6673)
    All,
    John
    John-------
    If the seal journal on the crankshaft is grooved or worn you should be able to see or feel it with the cap and seal removed.
    I believe that seals with an off-set lip are available. This way, the lip on the new seal contacts an unworn area of the journal. I've never used one but I think they ought to work well.
    • Mark E.
      • April 1, 1993
      • 4611
      It's critical to follow the procedure outlined in the FSM; details like properly preparing the mating surfaces, and the location, quantity and type of sealant make a difference. It's also easy to install the seal backwards. There are some good threads on this forum that can help.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
