Rear Spring center Bolt - NCRS Discussion Boards
  • Jeff P.
    • 799
    I just put my spring together. Is there a rule of thumb on what to torque it at? Thank you, Jeff.
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
    • 43219
    Re: Rear Spring center Bolt
    Jeff-------
    It's really pretty unimportant as this bolt has little practical effect after the spring is installed in the car. However, I'd use about 15-20 lb/ft.
      • 6941
      Jeff, I find that the center bolt will loosen once the spring plate is installed and torqued after sitting on the ground.
      • Jeff P.
        • 799
        Thanks Ed and Joe. Spring is in.
