66 - Remove Exhaust Manifolds - NCRS Discussion Boards
  • Stephen L.
    • August 29, 2007
    • 205
    starting on drivers side
    followed Chassis Service Manual pp 6-28 and 6-29
    1. removed alternator and brackets
    2. plugs, shields, all bolts
    I seem to be hung up when trying to pull up and out on the steering box - i can't imagine that has to come out
    the other thought is removing the clutch fork push rod assembly (p 7-3 in the CSM) - is that really necessary?
    or is there just a tip or trick on angling that i am missing
    thanks!
    PS - looking ahead to the other side, have removed the battery and supports - does the dipstick tube need to be removed?
    • 43248
    Re: 66 - Remove Exhaust Manifolds
    thanks!
    Stephen------
    By chance, is this car equipped with K-19 (AIR) or was it ever so-equipped (i.e. plugged AIR fittings in the manifolds)?
    • Stephen L.
      • August 29, 2007
      • 205
      forgive my ignorance Joe, but i assume this would be/would have been fittings in the exhaust manifold
      not that i am aware of
      if someone happens to have a photo i can confirm
      i don't see any fittings, bolt heads or the like that are hanging it up
      it just doesn't seem to clear the steering box
      down low it looks like it might hang up with the clutch parts...but if i had clearance up high i could slide it a bit and avoid that (i think)
        • 6950
        Steve, Are you dealing with a big block or small block?
        • Stephen L.
          • August 29, 2007
          • 205
          Big Block Edward
          and on the other side am i correct that the oil dipstick tube has to come out? - there is a manifold bolt right behind it
          if so, the oil pan has to come off and then the tube tapped out from there? (seems like a lot to do to get 2 manifolds off!)
          • Stephen L.
            • August 29, 2007
            • 205
            on the clutch linkages, i don't think that is is...i had someone depress the clutch pedal and that pushed the push rod assembly out of the way -- sticking point seems to be the steering box - anyone have any thoughts?
            thanks
              • 43248
              Big Block Edward
              Stephen-----
              It should not be necessary to remove or unbolt the steering box to remove the left side BB exhaust manifold.
              It should not be necessary to remove the dipstick tube to remove the right side manifold although it might be convenient to do so. In any event, it is not necessary to remove the oil pan to remove the dipstick tube.
              Now, one more time: do your manifolds have AIR fittings, plugged or in-use? The AIR fittings can be seen in the photos below. They are located at the top of each exhaust runner.
              • Stephen L.
                • August 29, 2007
                • 205
                No Joe - i do not have AIR fittings
                  • 43248
                  Stephen------
                  Then, without the tubes internal to the fittings, I do not understand why you cannot remove the manifolds. You should be able to remove them from either above or below.
                  • Stephen L.
                    • August 29, 2007
                    • 205
                    Thanks Joe
                    i'll keep playing around with it and see if i can get it out
                    thanks, sl
                    • Patrick B.
                      • August 31, 1985
                      • 2003
                      The dip stick tube on a big block just pulls out without difficulty once the bracket is unbolted. I have taken off exhaust manifolds and tube headers from C2 and C3 Corvettes many times without ever touching the steering box, so don't worry about that. The clutch cross shaft is easy to remove and that was certainly necessary for the headers. I can't remember if that was necessary for the stock manifolds, but if you need to remove the manifold from the bottom, remove the clutch cross shaft and it will be easy.
                      • Joe R.
                        • May 31, 2006
                        • 1822
                        thanks
                        Hi Stephen,
                        I also have a 66 big block. It's been a while (2008), but I seem to remember pulling them out from the top. I don't recall any major struggle with it. I don't have power steering, air conditioning or power brakes or anything else that might rob power from the ole' L72.
                        Joe
                        • Stephen L.
                          • August 29, 2007
                          • 205
                          Thanks Patrick and Joe R
                          I should have mentioned the steering is power steering...maybe that box is a touch bigger?
                          either way Patrick's route is clear to me - if the clutch cross shaft is not there, it will drop out with ease - i'll work it that way
                          on the dip stick tube i was reading posts about it being a press fit...but i am thinking now that may have been a small block - i'll give it a try
                          thanks to all
                          on refinishing, the route i am going is to use evaporust to not alter the finish and then leave it bear metal and occasionally spray w wd 40 to keep rust to a minimum - i understand a little rust needs to be there or there will be a point deduct - (oh, and little overspray as the current finish has) - any other thoughts are welcome - i have never had a car judged and so am working through issues very slowly and feeling my way along.....
                            • 43248
                            thanks to all
                            Stephen-----
                            The steering gear box for power steering is exactly the same unit used for cars with manual steering.
                            • Stephen L.
                              • August 29, 2007
                              • 205
                              then like you i am stumped why it won't come out the top - but it seems like there is a bottom-out solution that should work...so we'll see where that goes
                              thanks to all
