1966 rocker panel birdcage brackets; when did it change from 6 to 3 per side? - NCRS Discussion Boards
  • Sven C.
    • July 18, 2015
    • 189
    #31
    Re: 1966 rocker panel birdcage brackets; when did it change from 6 to 3 per side?
    Gary,
    It is a roadster. No problem. I will remove the shield over the weekend and hopefully there is evidence of 6.
    Sven
    1963 Corvette: Flight Judging Award (Top Flight) at 2023 Ontario NCRS Regional Meet (Regional) at 09-14-2023
    1963 Corvette: Flight Judging Award (Top Flight) at 2023 National Convention-French Lick (National) at 07-27-2023
    1963 Corvette: Flight Judging Award (Top Flight) at NCRS Indiana Regional (Regional) at 04-28-2022
    1963 Corvette: Flight Judging Award (Top Flight) at Ontario Chapter judging Meet 2021 (Chapter) at 09-18-2021
    • Gary B.
      • February 1, 1997
      • 7071
      #32
      Sven,
      Thanks in advance for double checking.
      Gary
      • Rich G.
        • August 31, 2002
        • 1405
        #33
        1966 Convertible. St Louis body. F07
        Has three
        Rich
        • Sven C.
          • July 18, 2015
          • 189
          #34
          Gary,
          Took the shield off the drivers side today and the only evidence left were three stumps where the brackets had been cut off. Definitely not six on my car.
          Sven
          • Gary B.
            • February 1, 1997
            • 7071
            #35
            Sven,
            Thanks for double checking. Will put you down for 3.
            Gary
            • Gary J.
              • April 1, 1980
              • 1246
              #36
              I just checked my St. Louis, K19 on the trim tag and I have 3 brackets for the rocker moldings.
              • Gary B.
                • February 1, 1997
                • 7071
                #37
                Gary,
                Thanks. Coupe? Or Roadster?
                Gary
                • Gary J.
                  • April 1, 1980
                  • 1246
                  #38
                  It is a Copue
                  • Gary B.
                    • February 1, 1997
                    • 7071
                    #39
                    Gary,
                    Thanks.
                    By any chance is your original frame stencil visible? I've got a database on '66 frame stencils that I wrote about for the Restorer. But no cars in mid to late July, unfortunately,
                    Gary
                    • Gary J.
                      • April 1, 1980
                      • 1246
                      #40
                      I remember putting the #'s on it when I restored over 30 years ago. I would have to pull the rocker off to read the #'s.
                      • Gary B.
                        • February 1, 1997
                        • 7071
                        #41
                        Gary,
                        Did you redo the numbers that you could read on the frame? Or do you get a stencil from Quanta with numbers based on their database?
                        If the number was based on your original number, I'd love to add it to my database if you get a chance to pull the rocker anytime.
                        Gary
                        • Gary J.
                          • April 1, 1980
                          • 1246
                          #42
                          I redid the # that was on the frame, when I get a chance I will try and get it for you.
                          • Gary B.
                            • February 1, 1997
                            • 7071
                            #43
                            Great. Thanks in advance. I'm trying to get confirmation for the correct stencil for my car, which was born two days after yours.
                            Gary
                            • Scott G.
                              • August 31, 1984
                              • 132
                              #44
                              AOS Body, Body Build G02, Body A-4279. It has 3 per side
                              • Gary B.
                                • February 1, 1997
                                • 7071
                                #45
                                Scott,
                                Gary
