Turn Signal Switch Installation - NCRS Discussion Boards
  • John L.
    • 103
    I purchased a new turn signal switch for my 66, and after thoroughly reading thru the archives about the installation process, I'm ready to start the job. I plan to replace the switch and harness, and now my question which is pretty basic. I am having trouble detaching the wires from the plastic arched connector at the end of the harness, is there a trick to this? Thanks for your response.
  • Paul S.
    • June 30, 1982
    • 359
    Re: Turn Signal Switch Installation
    Small pointed "pick" and carefully depress terminal and terminal will come out of the plastic connector . Grts easier once you get a system figured out.
    • David Z.
      • April 1, 2002
      • 182
      Here is some info on dealing with the Packard 56 type terminals.
      Hope this helps.
      Dave Z
      Dave Zuberer
