66 hand brake and lights on warning wont flash - NCRS Discussion Boards
  • Mike G.
    • January 2, 2016
    • 23
    Hi all,
    All of a sudden, my hand brake and "lights on" warning lights no longer flash, they just stay on solid. I know they have to warm up so I left the headlights on (closed) for 10 minutes and still light is solid...ideas?
    Mike
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 66 hand brake and lights on warning wont flash
    Time for a new bulb... The "flasher" is a set of contacts inside the bulb which are probably "welded" together.
    • Mike G.
      • January 2, 2016
      • 23
      OK...now how on earth does one replace those guys?
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        With much difficulty.....
        Lower the steering column a bit and use long 1/4-20 carriage bolts( or threaded rod) replacing the Cluster face Phillips screws one at a time. Slowly pull the cluster out paying close attention to the oil line.
        Reach over the top edge of the cluster to swap out the bulbs. Suggest you find original NOS GE #257 bulbs before you go through all of this effort. Repro bulbs are junk.
        Rich
        • Harry S.
          • July 31, 2002
          • 5344
          Do a search on the bulb number. They were made by the millions in the 50's and 60's for the toy train collectors. They were in the engines. The price range will be from $100.00 down to the $5.00 range. Same bulb, pay the $5.00. Buy a few xtras
          • Mike G.
            • January 2, 2016
            • 23
            Thanks everyone. I just find it odd that they would both go out at the same time.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11364
              Hmmm, I'm wondering if your voltage regulator may be acting up and went overvoltage by sticking on. Next time it's idling place a voltmeter on your battery and check charge voltage. Shouldn't be more than 13.6 volts or so.
              I landed a 10 pc box of GE#257's a few months ago on Ebay for $15.
              • Harry S.
                • July 31, 2002
                • 5344
                Rich, I was thinking the same thing, power surge.
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11364
                  Yes, maybe.....
                  Mike, did the lights seem brighter than normal? If your dash lights seemed normal, it may have been because the Headlight Switch dimmer had them at reduced brightness.
                  The Park Brake and HL LAMPS bulbs are not controlled by the dimmer switch so it could be a overvoltage condition going on. Something may have in fact welded the bimetal heat strip in the bulbs to the filament contacts as suspected by Stephen.
                  Rich
                  • Stephen L.
                    • May 31, 1984
                    • 3162
                    While you are replacing the bulbs you might want to replace ALL of them in the cluster, especially if they are original/old.......
                    • Mike G.
                      • January 2, 2016
                      • 23
                      Thanks all...great advice!
