1966 Rear End Identification - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1308
    The code on the rear end is FA 071265
    If I look up this FA code in the NCRS Corvette Specifications Guide, this FA is shown as a 3:70 for a 427. Yet if I look the same code in Noland Adams Restoration Guide, it shows the code being related to a 3:70 for a 327.
    Conflict of information??? Can someone help me distinguish between these two reliable sources of information?
    Jerry
  • Wayne L.
    • September 30, 1981
    • 233
    Re: 1966 Rear End Identification
    Alan Colvin's "Corvette by the numbers" shows 3.70:1 for a 427 engine. IIRC, codes starting with "F" were all for big blocks.
      • 43263
      Jerry
      Jerry------
      "FA" is the code for a 3.70:1 positraction axle ratio with 427 (all 427's were positraction). The code for 1966 327 with 3.70:1 positraction axle is "AO". The only difference between the 2 carrier assemblies is that the "FA" coded has cap type stub axles. The "AO" coded has u-bolt type stub axles.
      • Wayne L.
        • 233
        And the NCRS 1966 TIM & JG, and the NCRS specifications guide both agree with Joe, etc.
        • Gary R.
          • April 1, 1989
          • 1804
          Jerry------
          " The only difference between the 2 carrier assemblies is that the "FA" coded has cap type stub axles. The "AO" coded has u-bolt type stub axles.
          Hi Jerry,
          Joe brought up a very good point here, while not specific to your question it is relevant to guys looking to buy used differentials. Many times I have heard guys paying more then a used differential is worth only because it is a BB differential, as if that was somehow stronger then the SB diff's. This a myth, the only difference is the stamping and the axles. I have never seen an axle fail at the yoke, twisted splines and worn faces yes. The BB diff's have the same issues the SB ones do. Now the value to a car to have the correct date and stamping is another story.
          • Gerald C.
            • June 30, 1987
            • 1308
            Thanks everyone,
            So I guess Nolan Adams Restoration guide is incorrect?
              • 43263
              Thanks everyone,
              Gerald------
              If he says that the "FA" code is for a 327, then he's incorrect.
              By the way, GM also says that "FA" is the code for 1966-67 with positraction and 427.
              • Wayne M.
                • March 1, 1980
                • 6414
                Thanks everyone,
                No, he's correct, as you are reading it from the list of ECL's (exception control letters) for the G81 (posi) option [page 342 for 1966 MY].
                The window sticker posi code for this car would have read: 02G81FA.
                • Gary R.
                  • April 1, 1989
                  • 1804
                  I checked one of my books for 1966, the BB cars were
                  AT= 308
                  AU = 336
                  AZ= 355
                  FA =370
                  FB =411
                  FC= 456
