C3 1977 Heater Hose routing - NCRS Discussion Boards
  • Frank K.
    • January 1, 2000
    • 319
    On a non air conditioned car can a shut off valve be placed in the hose off the water pump? The reason is constant heat with controls in car in the off position.
  • Mark E.
    • April 1, 1993
    • 4536
    Re: C3 1977 Heater Hose routing
    Sure. That's a common practice for drivers without a factory installed valve. Some use two valves, one for each hose.
    I completely disconnected the heater core, which eliminates hot coolant in the cabin altogether. Of course it's more work to restore heater function, but that feature for a big block driven in Texas is superfluous.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
