Ignition Shielding Information Request - NCRS Discussion Boards
  • Harold A.
    • November 6, 2015
    • 9
    The pictured ignition shielding came with my 1967 Corvette (L79). Can you confirm what year it is for, I don't think its correct based on what I have found on this site. Thanks in advance for your help. thumb_IMG_4317_1024.jpgthumb_IMG_4318_1024.jpg
  • Alan D.
    • January 1, 2005
    • 2053
    Re: Ignition Shielding Information Request
    Rivets on top are metal or plastic?
    • Harold A.
      • November 6, 2015
      • 9
      They are plastic.
      • Jeff S.
        • July 31, 1984
        • 384
        Harold
        I'll speculate from examining your two pictures that it's a '65 model year (3864671) with the top portion of the front grounding clip broken off; a 'carb' rear grounding clip, but attached in the cover's FI slot.
        • Harold A.
          • November 6, 2015
          • 9
          Thanks for the response. Anyone want to trade for a 67 ignition shield?
          • Loren L.
            • April 30, 1976
            • 4104
            Harold, the best article on 63-7 Shielding was done by John Amgwert in the Corvette Restorer and was reviewed before publication by at least 15 people. Seek it out.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11364
              Vinnie Peters loaded it on here a while ago....HERE
              • Harold A.
                • November 6, 2015
                • 9
                Thank you.
                • Richard P.
                  • September 29, 2011
                  • 96
                  Richard, I just found this thread with the link you provided to reach the John Amgwert article. When I tried the link I only got an error message. Do you know if this link has expired and whether or not there is another way to reach John's article?
                  Thanks, Richard Powell
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11364
                    Richard, Send me a PM with your email address and I'll emai it. It's too big to attach here on the TDB as it exceeds filesize limits.
                    Rich
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11364
                      Rich
                      Richard, Got your PM. Just emailed to you. It's apx 4.75Mb, fine for email, but too big as a attachment here.
                      Rich
                      PS I think when Vinnie Peters puts these files on the server, it's for temporary use only. That's why it gives a FIle Not Found Error.
                      • Gerard F.
                        • June 30, 2004
                        • 3806
                        Harold,
                        It sure looks like the shielding dome on my original 67 327/300. Plastic rivets on the top.
                        Can't tell for sure from the photo, but it looks like the front clip to the air filter housing has been replaced. One should see only two rivet heads holding the clip in place. The rivet washers should be on the inside.
                        Jerry Fuccillo
                        • Gerard F.
                          • June 30, 2004
                          • 3806
                          Harold,
                          Here's a thread on replacing the ignition shield front clip on my 67
                          https://www.forums.ncrs.org/showthre...gnition+Shield
                          Jerry Fuccillo
                          • Enzo C.
                            • January 12, 2012
                            • 536
                            Does anybody have one available for a 67....327/300
                            Enzo Colosimo
                            Ncrs Ontario Chapter Chairman 🇨🇦
                            ENZ-Z06/67
                            • Gerard F.
                              • June 30, 2004
                              • 3806
                              Harold,
                              I compared the pictures you posted with my original 67 327/300 and they almost look exact (except for the replaced front clip)
                              Here's a picture of mine before I replaced the broken front clip (broken is usual):
                              Just for fun, here's how to clean your ignition shielding (only when your wife is away):
                              Jerry Fuccillo
