63 wiper arm removal - NCRS Discussion Boards
  • Thomas S.
    • February 7, 2016
    • 618
    For reasons unknown, the wipers on my 63 started interferring with each other on their way back down. I am in the process of replacing the insttument cluster so the column is out and the cluster ready to be remounted. I discoverd the issue with the wipers while testing the cluster for functions, lights etc. The under dash linkage is properly positioned and there is no apparent interference.
    The wiper arms appear to be original and there is no play or loosness on the wiper shafts. The blade holders are a bit wiggly and the windshield was dry when I test them but otherwise every thing is exactly like it was before.
    I checked the AIM & shop manual for instructions on how to remove the arms for realignment but I couldn't find anything. I know there is a retaining tab that has to be released and a screw-drive could be used to pry off the arm but i was wondering if the is a specific tool to make this easier and also prevent accidental damage to the trim or body.?
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
  • Stewart L.
    • March 1, 1980
    • 355
    Re: 63 wiper arm removal
    You can get a wiper arm removal tool at an auto parts store or probably even Amazon for about $10.
    • Thomas S.
      • February 7, 2016
      • 618
      the ones I've seen look like wheel pullers and require the end of the shaft to be exposed. this may be a dumb one but, on that year , does the stainless steel cover at the end of the arm lift off to expose the shaft end?
      • Chuck G.
        • May 31, 1982
        • 2036
        Here's what you want. You do NOT want the wheel puller type. A friend of mine ruined his 67 wiper arms using the "wheel puller" type tool.
        • Frank D.
          • December 27, 2007
          • 2703
          Yes, I just used that tool on my '63 to remove PS wiper arm to get down in the cowl area....just stick the hooked end under the wiper arm's chrome barrel, grasp the tool AND the wiper arm with one hand and 'rock' it off...
          • Thomas S.
            • February 7, 2016
            • 618
            Thank you for that and the photo as well. I saw that listed as an option but couldnt tell for sure how it worked. The phot mad a big difference.
            • Stuart F.
              • August 31, 1996
              • 4676
              I've got the same tool and it works fine, but every time I tried to reposition mine it seems I ended up in the same position with too much gap between the blades. I finally got smart and used the nifty screw adjustment and found I could move the arm enough to get a real nice fit. I was always afraid to try that as I thought I would scratch the arm, but if you find the right screw driver and are careful, it will work fine. I never thought there would be enough adjustment with the screw either, but a few turns lower down within the arm makes a big difference further out to the end.
              Stu Fox
              • Thomas S.
                • February 7, 2016
                • 618
                Which screw are you referring to? I know there is one on the back of the arm but I thought that was for the spring tension.
                • Stuart F.
                  • August 31, 1996
                  • 4676
                  There is only one screw on the top of the "u channel" portion of each arm assembly. It has a chrome flat screw head on it, and it threads completely through the arm. Try turning it and you will see the result. The outer "flat portion" of the arm will move in relation to the channel.
                  Stu Fox
                  • Barry H.
                    • April 30, 1976
                    • 213
                    Guys, Snap-On also made a wiper arm removal tool under part #JT-85, have been using one since 1962
                    Barry
                    • Bob R.
                      • June 30, 2002
                      • 1595
                      I have noticed many midyear cars have the wiper arms installed incorrectly. The passengers side should be above the drivers side, if installed incorrectly the arms hit each other. Another cause for problems is the post on the back of the wiper motor that the transmission rotates on. The post can wear causing a very sloppy operation of the arms. This post can be changed and if you have the instrument cluster out it should be easy to get at.
                      • Thomas S.
                        • February 7, 2016
                        • 618
                        I looked at the arm assembly and the flat portions on mine are actually riveted to the channel so movement is possible. The screw is there like you mentioned, but nothing moves when you turn it. They are Trico arms, stainless, etc. So either the arms are not correct or this is one of those many running changes that were made on 63's. Mine is a July 63 build.
                        • Bob W.
                          • December 1, 1977
                          • 802
                          Looks like a great tool to have for $4.00.
                          Bob
                          • Stuart F.
                            • August 31, 1996
                            • 4676
                            Thomas;
                            Mine is also a July build and the screws work great. Perhaps you need to turn it some more. It's a fine thread.
                            Stu Fox
                            • Stuart F.
                              • August 31, 1996
                              • 4676
                              My blades were about an inch and a half apart and I used the screw to close the up the gap.
                              Stu
