Re: C1 Wiper Transmission
Rich...I'm glad you noticed the small bushing...when I disassembled the unit.......it fell out of the larger pulley end of the housing (as opposed to smaller diameter wiper/arm end) I have not seen it on any of the 3 different exploded views that I have seen. Maybe the linear spring is a little shorter on my unit? After everything is assembled though..... the short spline and the longer main shaft splines (as in photo #1) seem to align well.
I'm still puzzled why the two pulleys with the spring inside will not align properly. Maybe I'll work with (the new) spring ever so slightly to get it to fit properly. Maybe I'll shorten both extended ends by grinding them off a LITTLE bit. Got any other ideas??
