Best sources for Power Steering Control Valve 1972 - NCRS Discussion Boards
  • Charles P.
    • April 30, 2005
    • 332
    I recently replaced my Power Steering Control valve with a NOS GM part I found at a Swap meet. It looked to be in mint condition but unfortunately it has been leaking. Close inspection has confirmed that it is the valve and not a hose. So my question is what would be the best source for a correct valve that hopefully will not need to be replaced? My choices are the GM parts counter, NAPA, LoneStar etc.
    • 43290
    Re: Best sources for Power Steering Control Valve 1972
    Charles-------
    Leaks in these valves is a long-standing common problem. However, I am surprised that an NOS GM valve leaked from the get-go. It might leak not-too-long afterwards, but I would not expect it immediately after initial installation. A new valve from GM is no longer an option as it is discontinued. If you could buy it from a GM dealer it would come with a warranty but a swap meet valve is probably not going to be so-covered.
    Consequently, I would probably go with a valve that comes with a warranty. This probably includes many suppliers. However, I might favor Lonestar or A-1 Cardone. A-1 Cardone is a high quality rebuilder that usually bench tests its parts.
    • Joe R.
      • July 31, 1976
      • 4552
      Charles,
      There is a problem in the market presently for PS control valves. Example: Lonestar has no rebuilt or new ps control valves as of last week. If you can find one anywhere it would be advisable to grab it up!
      JR
        • 11698
        Many of the parts houses sell rebuild kits for these. If you're at all mechanically inclined you might consider rebuilding the NOS one.
        And, remember that the 1972 unit did not originally have the metal "gravel guard" on it.
          • 43290
          Patrick------
          "Gravel guard" is a misnomer. The device of which you speak is correctly termed a "hose guide". And, yes, 1972 did not have this component. It was not added until 1975.
          • Bill L.
            • April 1, 1985
            • 349
            I would try Lonestar Caliper:
            I have used them quite a bit in the past and they do some very nice work.
            I have purchased a number of their products over the years and have never had an issue.
            Hope this helps a bit---
            Regards
            Bill
              • 43290
              Patrick-------
              Here's the deal on what I believe is the "Achille's Heel" of these valves:
              Within the valve assembly is an unusually configured metal gasket, GM #5691581. This gasket was GM-discontinued years ago. I have never seen an adequate replacement available and none is included in any kit I know of. The valve rebuilders and valve manufacturers must have something available but I have a sneaking suspicion that what they're using is not the equal of the original GM gasket and is not "up to snuff". That's why I think the valves leak, either right away or soon thereafter. This gasket is the "Achille's Heel" of these power steering control valves.
              • John M.
                • January 1, 1998
                • 813
                I've tried rebuilding and buying rebuilt and had zero luck until I bought a Lonestar rebuilt. It's perfect.
                • Mark E.
                  • April 1, 1993
                  • 4614
                  I got mine from NAPA during their 2nd Saturday 30% off event. I don't remember the net price but it was very affordable. No leaks after two years, and a lifetime warranty if it does leak. Similar deal for the cylinder and hoses too.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Pete B.
                    • February 22, 2007
                    • 328
                    I rebuilt my original... like others have said not that difficult if your so inclined. Actually was a fun project and it worked... with no leaks!
                    Pete Bergmann
                    2005 - 2013 C6 National Teamleader
                      • 43290
                      Pete------
                      Where did you get the gasket I mentioned in an earlier response? It's not included in any gasket set I know of, including the various GM gasket sets (when they were available).
                      • Pete B.
                        • February 22, 2007
                        • 328
                        Joe....
                        I just bought a control valve rebuild kit... Paragon part # 2656K To be honest... I just disassembled it... if there were parts to be used over I reused. My car had 56k miles and just needed a refresh (all over)
                        Parts/kit worked fine.. no leaks in 4 years and sold last year into Sweden.
                        Was there configurations internally? maybe, none stood out... I just wanted to see if I could do it.
                        Like I said pretty simple task. I used the shop manual for guidance.
                        This era of car was not rocket science... and assembly/service was engineered to be simple and replicated by people of various skill levels.
                        Pete
                        Pete Bergmann
                          • 43290
                          Joe....
                          Pete
                          Pete------
                          Yes, rebuilding the valve is not difficult, at all. It's very straightforward. I'm a bit surprised, though, that you got away without leaks if you re-used the 5691581 gasket (which you apparently did). This gasket is an embossed metal gasket of unusual configuration. It seals by compression of the embossed areas. It's, basically, a "one-time-only" sort of gasket.
                          • Pete B.
                            • February 22, 2007
                            • 328
                            Probably a case of ignorant luck.... If I knew it was a one time use part I probably would have had a leak.
                            But then....
                            My brother was a line mechanic for a large GM dealer here in Phoenix during the seventies... when they would do overhauls of rear ends they would be issued ring & pinion gears along with gaskets, seals and crush sleeves. They never would use the new crush sleeve as it meant more time getting the preload right. They would set them by feel, and take the sleeves home and use them for target practice .
                            Pete Bergmann
                            • Gary R.
                              • April 1, 1989
                              • 1808
                              Probably
                              That's something, I use a new sleeve on every build and dial it in between 18-20 in/lb, same when fitting a solid sleeve. I wonder how close those diff's were.
