1970 Convertible Top front Latch Rubber - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 887
    My latches are in great shape; however, someone has removed the rubber from the handles. Is the rubber available? Has anyone repaired this problem? I thought about dipping the handles in the liquid rubber handle product sold at hardware stores. Thanks in advance for any advise and suggestions.
    • 43294
    Re: 1970 Convertible Top front Latch Rubber
    Stephen-------
    Are you talking about the latches on the convertible top or the latches on a hard-top? I say that because the hard-top latches do not have and never had a rubberized coating.
    If you are, indeed, talking about the convertible top latches, I do not know of any source for the rubberized covering. Certainly, the covering was never available separately from GM.
    • Stephen B.
      • April 1, 1988
      • 887
      Thanks Joe. I'm going to try the spray on rubber handle and see if I can replicate a bit.
        • 43294
        Stephen-------
        Keep in mind that the original rubber coating on these handles was a very matte black finish with a slight texture. It was not "shiny black and slick".
        • Stephen B.
          • April 1, 1988
          • 887
          Thanks for the reminder Joe. I will see if I can replicate. I have a couple of old handles from another '70 i have as a pattern.
