C2 (2 1/2") Exhaust Clamps --- Again--- - NCRS Discussion Boards
  • Bill L.
    • April 1, 1985
    • 349
    HI:
    There has been a ton of traffic here on clamps but I still wanted to get some opinions...
    Which (if either) of these 2 1/2" clamps are correct?
    Screen Shot 2016-04-25 at 3.10.22 PM.jpgScreen Shot 2016-04-25 at 3.06.42 PM.jpg
    Thanks in advance for any input on this----
    Regards
    Bill
  • Alan D.
    • January 1, 2005
    • 2039
    Re: C2 (2 1/2&quot Exhaust Clamps --- Again---
    I'm used to the one on the right which I use on mine. Now if you can find one with a part number that may answer the question.
    So the part number for the 2 1/2 clamp should be the one for HP/FI, poor picture but one can read if you down load and enlarge.
    And here is some more information on these from GM sources I have been saving, it may be a little tough to follow;
    middle clamp
    63AIM Sec 8 sheet 6.00 regular exhaust
    64AIM Sec 8 sheet A2.00 regular exhaustU Bolt exh pipe clamp (3/16-18) 3824283
    63-64 Corv w/H/Per Sp. H/Per, FI (exc PG) U Bolt front exhaust pipe clamp (3/16-18) 3824528
    63-64 Corv w/H/Per Sp. H/Per, FI (327) Clamp UnitClamp UnitU Bolt exh pipe clamp (3/16-18) 3824283
    63 Corv w/H/Per Sp. H/Per, FI (exc PG) U Bolt front exhaust pipe clamp (3/16-18) 3824528
    Gary Beaupre, ncrs, 11/3/12
    Do anyone know if any of the repro 2.5" clamps have a 5/16" thread?
    66 – 67 nut is flanged pn 1359887 replaced Sept 79 to 271184
    1359887 is Gr 8.917 HFH (5/16 – 18 13/64 286M PC
    • Bill L.
      • April 1, 1985
      • 349
      Thanks Alan:
      This is some good documentation ---
      One of the things that I have been told about the clamps is they need to be fine thread --- and the 2 1/2" stamping is inside a circle --- like the clamp on the right. I have a few in my collection but I have never had anyone tell me definitively what all of the markings and measurements are.
      I tend to go with the one on the right as well but only because of the 2 1/2" stamp being inside the circle... otherwise these seem pretty similar.
      However, I will also say the the depression is different on both clamps... the one on the right is much deeper and more pronounced than the one on the left.
      Thanks!!!
      Bill
      • Gene M.
        • April 1, 1985
        • 4232
        Originally posted by Bill Lucia (8620)
        Thanks Alan:
        Thanks!!!
        Bill
        No, mid year clamps are 5/16 -18, which is course thread. The solid axle cars were using 5/16 fine thread. I think original supplier was Arvin. Your callouts for thread size (3/16-18) must be typo.
        • John D.
          • December 1, 1979
          • 5507
          Alan, Nice presentation. My '63 has the right clamp on Lucia's. Course thread for sure.
          Jorjorian has a bunch for sale on Ebay right now. Not sure if they are correct though. John
          • Bill L.
            • April 1, 1985
            • 349
            Thanks Gene:
            This has been frustrating to say the least --- the issue of fine vs. coarse has become problematic....AND:
            For what it's worth, the NEW '67 AIM (page 204) calls out ... "fine thread hex flange nuts"-----
            Given what I am seeing in the way of original and NOS clamps --- and what you are indicating -- I am thinking its coarse thread !!!!
            Thanks!!
            Bill
            • Jim S.
              • March 13, 2013
              • 360
              Thanks Gene:
              Thanks!!
              Bill
              If you need correct clamps contact Greg Thompson at gt66duntov@gmail.com
              • Bill L.
                • April 1, 1985
                • 349
                Thanks Jim...I will contact him.
                Regards
                Bill
                • David L.
                  • July 31, 1980
                  • 3310
                  The 2 1/2" U-bolt clamp on the left (below green box) has 3/8"-16 threads (length of threads measures 1 5/8") and is made by Versatube Corp., Troy Michigan. There are no stampings.
                  Also, a page from my 1969 Chev. Parts Catalog.
                  My 1963 Chev. Parts Catalog lists GM # 237616 for the 2 1/2" CLAMP UNIT for the 63 Corvette w/HP, SHP, and FI. This appears to be a misprint as it was corrected in my 1964 Chev. Parts Catalog as GM # 2378616.
                  My 1965 Chev. parts catalog lists GM # 2378616 for the 2 1/2" CLAMP UNIT.
                  GM # 2378616 was replaced with GM # 9784420 in Feb. 1968 which was then replaced with GM # 3633128 in June 1970 as per Chev. Parts History.
                  Dave
                  • Alan D.
                    • January 1, 2005
                    • 2039
                    Interesting -- "No, mid year clamps are 5/16 -18, which is course thread" The number that David Liukkonen posted below of 2378616 is used throughout GM. If the clamp under that number was either a fine or course would think the pn would change however I find a few old catalogs listing it as a 5/16-18 thread. Also the diagram of 63 corvette exhaust calls for 5/16-18 nuts on multiple clamps. So the story is not over yet, is it? By the way David also found the number 237616 in two cat, P&A Feb 61 and P&A Oct 62
                    • Gary B.
                      • February 1, 1997
                      • 7024
                      Guys,
                      Via an inspection of a '66 Bowtie car and based on supporting evidence from the '66 AIM I can tell you that the U-bolt and nut thread for the 2.5" clamp at the center clamp of '64-'67 is 5/16-18. The '66 AIM calls out part #1359887, which is still sold by GM for a list price of $4.56. I purchased some and I can confirm they are 5/16-18, which is the coarse thread.
                      Gary
                      • David L.
                        • July 31, 1980
                        • 3310
                        GM # 237616 appears in my 1963 Chevrolet Parts Catalog (Oct. 1962) but GM # 2378616 does not.
                        However, GM # 2378616 (Gr. 3.708) does appear in my Chevrolet Dealer Parts and Accessories Price Schedule (Oct. 1962) with list price of $0.60. GM # 237616 does ​not appear in this same price schedule so I truly believe that it is a misprint.
                        Dave
                        • David L.
                          • July 31, 1980
                          • 3310
                          Originally posted by Gary Beaupre (28818)
                          Guys,
                          Gary
                          Gary,
                          My GM English & Metric Standard Parts Catalog (Oct. 1978) lists GM # 10008001 in Gr. 8.917 as a 5/16-18 Hex Flange Nut, grade 286M, Phos. Org. Finish while my GM Standard Parts Catalog (Oct. 1988) lists GM # 1359887 in Gr. 8.917 as a 5/16"-18 Hex Flange Nut, grade 286M, Phos. Finish with a thickness of 13/64".
                          As per my GM Parts History Catalog (Jan. 1982 to Jan. 1990) GM # 10008001 was replaced with GM # 1359887.
                          GM # 1359887 also appears in my 1966 Corvette AIM (UPC 8, sheet A2) as you mentioned.
                          GM # 1359887 is not listed in my Chevrolet Dealer Parts and Accessories Price Schedule (Oct. 1966).
                          Dave
                          • Gary B.
                            • February 1, 1997
                            • 7024
                            Dave,
                            So what's the difference between 10008001 and 1359887? They sounds near identical to me.
                            Gary
                            • David L.
                              • July 31, 1980
                              • 3310
                              Dave,
                              Gary
                              According to the Standard Parts Catalog the thickness of the 1359887 hex flange nut is 13/64" (or 0.203").
                              Maybe the 10008001 nut was a different thickness.
                              What is the difference between "PHOS." and "PHOS. ORG."?
