Judging Tires - NCRS Discussion Boards
Judging Tires
  • Frank K.
    • January 1, 2000
    • 319
    Judging Tires
    How many points do they take off for a non delivery tire? This is a C4 vehicle I am talking about. Tires would not be original to the car but same mfg.
  • David K.
    • September 30, 1979
    • 241
    Re: Judging Tires
    You need to give us more info on the tires, what year, run flats or not, did the car have run flats or not RPO code WY5 ?
    With out that info it would be anywhere from 10%-60% deduct. That's not much help is it.
    • Frank K.
      • January 1, 2000
      • 319
      Re: Judging Tires
      The car is 1993. The car was ordered with non run flats. Goodyear were the brand. The replacements will be good year.
      • Tom R.
        • June 30, 1993
        • 4102
        Re: Judging Tires
        What Davis is referring to is the table of standard deductions for a 1975 or later tire:
        Deduct 10%---OEM brand and size tires which differ from original only because of markings or other minor differences.
        Deduct 20%---OEM brand, type and size tires which differ slightly from original in design, construction, material, tread width, tread pattern, style lettering or pattern.
        Deduct 30%---OEM brand, type and size tires which differ considerably from original in design, construction, material, tread width, tread pattern, style lettering or pattern.
        Deduct 60%---OEM brand that is of the extended mobility type (run flat) on a car that does not have WY5 in the list of RPO’s on its Service Parts Identification Label or OEM brand but tire is not of the extended mobility type (run flat) on a car that does have WY5 in the list of RPO’s on its Service Parts Identification Label.
        Deduct 75%---Non-OEM brand, with correct size and lettering.
        Deduct 100%---Originality and Condition for incorrect size or those with white letters mounted inboard or outboard.
        Tom Russo
        78 SA NCRS 5 Star Bowtie
        78 Pace Car L82 M21
        00 MY/TR/Conv
        • Frank K.
          • January 1, 2000
          • 319
          Re: Judging Tires
          Excellent! Thanks its very clear to me.
