62 speedometer needle bounce - NCRS Discussion Boards
  • Kenneth F.
    • September 30, 1988
    • 285
    The speedo needle is steady if I remove the cable assembly from the transmission and use a drill motor to operate the speedometer. I removed speedometer gear assembly from the transmission. I noticed if I thread the cable to the gear assembly, the gear is pushed away from the gear housing 5/16." Should I drill through the gear to remove a restriction so the excess cable has a place to extend to? Could I grind the end of the cable without having the strands unravel? Buy another cable?
    Thanks, Ken
  • Dan H.
    • July 31, 1977
    • 1372
    Re: 62 speedometer needle bounce
    Ken, I had to grind some off my 64 tach cable on the tach side, was too long to seat, worked out fine.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Kenneth F.
      • 285
      Dan, I will try shortening the cable.
      Thank you,
      Ken
      • Stephen R.
        • May 20, 2008
        • 302
        Thanks, Ken
        I may be wrong but if you remove the restriction in the driven gear, you will have trans oil climbing up the speedo cable.
        • Kenneth F.
          • 285
          Stephen, The restriction in the gear stopping oil from going into the speedometer cable makes sense. Thanks for the information.
          Ken
