Ignition coil loose screw in secondary contact - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    In a original Delco 207 service replacement coil, the screw was loose holding the secondary barrel contact in the snout.
    I removed the screw and cleaned the barrel contact. There is a flat washer below the contact barrel. There was no lock washer under the screw head.
    Should there be a lock washer under the screw head to capture the barrel?
    Rich
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    Re: Ignition coil loose screw in secondary contact
    I found out from a friend that restores coils........No Lock Washer used.
    Rich
