Carb question - NCRS Discussion Boards
Carb question
  • Mike M.
    • February 26, 2008
    • 57
    Carb question
    Looking for the best holley carb rebuilder for NCRS style rebuilding?
    Thanks in advance
  • Michael M.
    • February 1, 1993
    • 605
    Re: Carb question
    Custom rebuilt carburetors in Middlesex, N.J. Talk to Phil Cancilla at (732) 356-4333
    • William F.
      • June 9, 2009
      • 1364
      Re: Carb question
      Lots of previous threads on this subject. Some shops recommended; some not. I'd check them and email or talk to members who have used various ones to check their experiences. Eric Jackson at Vintage Musclecar Parts does a good job and is good to work with.
      • Bill L.
        • April 1, 1985
        • 349
        Re: Carb question
        Bob Kunz and Jerry Luck are both very good --------
        • Terry D.
          • May 31, 1987
          • 2697
          Re: Carb question
          What Bill said
          • Daniel Y.
            • September 30, 2002
            • 186
            Re: Carb question
            Jerry is good but he uses the wrong screws for the butterflies. I agree with Mike send to Phil
            Dan Young
            65, 67 Duntov x2
            66 bowtie x 2
            71 LT1 TF
            90 ZR1 McCelland
            03 Anniverary
            06 Z06
            • William F.
              • June 9, 2009
              • 1364
              Re: Carb question
              Are the "wrong screws" used because they're better than originals??. Are butterfly screws judged?
              • Daniel Y.
                • 186
                Re: Carb question
                yes, they are judged. Philips or slotted are acceptable but torx are not and that's what he uses. they aren't any better just different heads. many judges differ on color and size of the head but the only way to determine if they are original is to see the underside and you cant see that without taking the carb off to view the peen. original peens are very distinctive. Jerry does a good job but you will most likely loose a point for originality for the screws
                Dan Young
                65, 67 Duntov x2
                66 bowtie x 2
                71 LT1 TF
                90 ZR1 McCelland
                03 Anniverary
                06 Z06
                • Bill L.
                  • April 1, 1985
                  • 349
                  Re: Carb question
                  I have two 3370 dated carbs that Jerry did with the correct screws (one as a back-up and one on the car) the one on the car had zero deductions at the regional level.---- I am sure if you discuss it with him you can get the correct fasteners ---
                  I would also add that a lot of restoration services will perform at two different levels.... driver quality and "correct" quality ... NCRS, Bloomington etc etc.....it always helps to clearly state the quality of the expected restoration.
                  Just my two cents.....
                  Regards
                  Bill
