1963 SWC Cooling System - NCRS Discussion Boards
  • Sebastian S.
    Infrequent User
    • November 19, 2015
    • 22
    Good day, could I trouble someone to provide some specifics on the cooling system for a 63 SWC. In particular I am looking for additional information on how to properly check coolant levels and to which coolant should be used to top up the system or fill when drained. I have the original Harrison expansion tank setup so I'm not 100% sure on what the coolant level should be at within that tank. If the car is cold should I be seeing any coolant within that tank?
    Thanks in advance.
    • 15706
    Re: 1963 SWC Cooling System
    The remote expansion tank should be approximately half full when cold. This should be in the owner's and service manuals.
    • Don H.
      Moderator
      • June 16, 2009
      • 2278
      Check this thread for the info that Duke left out on best coolant to use in your 63.
      https://www.forums.ncrs.org/showthre...hlight=coolant
      also just below in Similar Threads you will see other discussions of coolant but they are older.
      • Frank D.
        • December 27, 2007
        • 2703
        Yes, 1/2 way in the surge tank on a cool motor....if you overfill it; it'll 'puke down' to its ambient level anyway.
        Make sure you have the proper pressure radiator cap....
        • Sebastian S.
          Infrequent User
          • November 19, 2015
          • 22
          Thanks for the assistance.
