Key Buzzer - NCRS Discussion Boards
Key Buzzer
  • Frank K.
    • January 1, 2000
    • 319
    Key Buzzer
    Did the 77 corvettes have key warning buzzards and where was the control located on a july built car?
    • 43288
    Re: Key Buzzer
    Frank------
    GM says it did. However, by very late 1977 I suppose things could have changed. In any event, GM says the buzzer was GM #6262663. It's GM-discontinued but not too hard to find. I do not know where it was located on the car.
    • Matt B.
      • August 31, 2001
      • 228
      Re: Key Buzzer
      Frank-
      My 1977 key buzzer module plugs into the right hand side of the fuse block. It's black and it's about 1/2" thick. My car build date is Nov. 76.
      Matt Beltowski
      Florida Chapter
      Michigan Chapter
      • Frank K.
        • January 1, 2000
        • 319
        Re: Key Buzzer
        Is it the size of a pack of cigaretes and have a pigtail on one end?
        • Matt B.
          • August 31, 2001
          • 228
          Re: Key Buzzer
          I attached a photo to my earlier response. It's smaller than a pack of cigarettes.
          Matt Beltowski
          Florida Chapter
          Michigan Chapter
          • Alan D.
            • August 31, 2000
            • 111
            Re: Key Buzzer
            My June 22, 1977 has the same buzzer and location as Frank's early 1977.
            • Frank K.
              • January 1, 2000
              • 319
              Re: Key Buzzer
              I checked it out and I was wondering is there any vendor who could repair it? I checked the control board out and saw no traces of burnt or carbon deposits. With Radio Shack going out of business I can not trace the components values (resisyors capacitor) etc Is there any part that would interchange with this from prior years?
                • 43288
                Re: Key Buzzer
                Frank------
                I finally dug this one out [not for sale]. This is what you're looking for but it's quite difficult to find. I do not know if these can be repaired.
                • Frank K.
                  • January 1, 2000
                  • 319
                  Re: Key Buzzer
                  It is made in Canada. I should visit a couple of Chevy dealers in my area may be I can get lucky. Another avenue is to read value on each component and use a meter to ring out for continuity. If I had a schematic that would make troubleshooting quicker. It is funny that no one wants to repair these items because the later cars are loaded with boards that could be soldered and sucker out for repair. Another problem is with Radio Shack on its way out were do we find the components? The people in Canada probably sourced this out Thanks for your input
