1988 gas cap correct thread color - NCRS Discussion Boards
  • John G.
    • September 24, 2013
    • 245
    Pictured are two "S" gas caps. The TIM&JG states that the threads are "large off white plastic threads". Which of these two colors is the closest to correct?
  • Paul S.
    • December 13, 2013
    • 83
    Re: 1988 gas cap correct thread color
    Does either one have the correct date of manufacture stamped at the bottom?
    • John G.
      • 245
      Yes - the off color one which also has a green insert. I'm going to a scrap yard probably tomorrow so if I need something different now is the time.
        • 43258
        [ATTACH=CONFIG]69788[/ATTACH]
        John------
        The one that's closest to correct is the one on the left. I believe the one on the right originally appeared just like it although with, perhaps, a slightly yellower coloration. The one on the right has been exposed to gasoline for a long time. That's what causes it to darken considerably.
        • Pat F.
          • April 1, 1981
          • 856
          Attached are photos of two 1995 Corvette Gas Caps displaying a date code. The first shows 171-4. This is June 20, 1994. This is one a 1995 Corvette that has a build date code of August 4, 1994. The second shows 079-5. This is March 20, 1995.
          Hope this helps.
          PAT, Central New Jersey and Florida Chapters
          • John G.
            • 245
            Unless I can find a better one I'm going with the yellowed one. It has a date code of 1228 and my car is a 5/88 manufacture.
