Passenger-side Fresh Air inlet / Radiator Support extension screen coating - NCRS Discussion Boards
  • Ian G.
    • September 3, 2007
    • 1138
    My understanding is that the fresh Air inlet screen on a 58-62 (59 in my case) was not screwed onto the passenger-side radiator support extension bracket up behind the grill during blackout. Therefor, the screen and its mounting screws should not be flat black. Can someone confirm if the screen was raw steel or painted? The vendors show it semi-gloss black. is that correct? The underside of mine looks like it may have been coated in low grade black paint, but its pretty rusty so I can't really tell.
  • Chris S.
    • January 1, 2000
    • 1068
    Re: Passenger-side Fresh Air inlet / Radiator Support extension screen coating
    according to the JM - it was installed after black out - so the screws should not be painted but the part itself looks to be a dipped part
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Ian G.
      • September 3, 2007
      • 1138
      So probably the screen would be semi-gloss black, with cad or zinc plated screws then?
      • Chris S.
        • January 1, 2000
        • 1068
        correct sir
