63 SWC Door Vapor Barrier - NCRS Discussion Boards
  • Sebastian S.
    Infrequent User
    • November 19, 2015
    • 22
    Had to repair the vent window mechanism and was hoping to install new vapor barrier before installing the door panels. Just wondering what has been used to adhere the barrier to the door. Afraid to use something that will be permanent. Recommendations?
  • Leif A.
    • August 31, 1997
    • 3633
    Re: 63 SWC Door Vapor Barrier
    Sebastian,
    Use a small bead of dumdum.
    Leif
    • Joe R.
      • July 31, 1976
      • 4551
      Sebastian,
      63 were a little different as usual in the fact that the barrier was thin brown paper! Would recommend using a later material which changed to clear plastic sometime later. Sure would do a better job of being a vapor barrier anyway.
      You can still purchase the 3M Strip Calk under part no 08578 black!
      JR
      PS. You could use Horse Feathers if you wish cause the NCRS 63 expert judges cannot see it anyway!
      • Ed S.
        • August 6, 2014
        • 1377
        I have the '64 AIM - just did my doors, not sure if the 63 AIM is the same but the 64 AIM indicates small pieces of tape placed in the corners and a few points along the long section of paper. It does not state the length of tape, but it does list the type or part number of the tape. Not sure it makes much difference. I used rubber electrical tape - the adhesive is not that strong and besides, it is impossible to see when you have the door panel in place.
        Dum Dum is placed on the back side (on 3 edges) of the two removable access panels that screw to the door.
        Ed
        • Bob R.
          • June 30, 2002
          • 1595
          I believe in 63 they used the 3M caulk or dumdum as mentioned above. Stick it on around the perimeter and press the brown paper into it.
          • Patrick T.
            • September 30, 1999
            • 1286
            Maybe Carlton will show up here and clarify this issue.
            • Bob J.
              • December 1, 1977
              • 715
              Better chance of Santa Claus and the Tooth Fairy dropping by.
              • Frank D.
                • December 27, 2007
                • 2703
                Hmmmph. I agree.
                The paper with the dum-dum is what was on my '63 coupe doors....however use that dum-dum SPARINGLY (or maybe not at all). When you have to go back into the door shells to work on something that black gunk has a way of attaching to your elbows, forearms, belly and forehead as you are looking and fishing around in the door to fix something. Or maybe I'm just sloppier than most...
                • Russ T.
                  • May 31, 1989
                  • 113
                  On some of my cars, I like to use 3M yellow spray adhesive to glue on the vapor barriers as well as on the carpet .
                  Russ Trotter NCRS #15044
                  • Mark D.
                    1984-86 Team Leader
                    • June 30, 1988
                    • 2152
                    That's hilarious:-))
                    Kramden
                    • Sebastian S.
                      Infrequent User
                      • November 19, 2015
                      • 22
                      Sorry everyone was away for a few days. I had a good friend also mention dumdum now I must ask is it available under a different name as I can't find it anywhere here in Ontario?
                      • Ed S.
                        • August 6, 2014
                        • 1377
                        Sebastian, the product you are looking for is "3M Automotive Strip Calk" - google that term and you will find a lot of sources, black is the most common color - I suggest that you wear rubber disposable gloves when working with it - you will lose (tear) a few sets of gloves (if you use the thin type) but better than trying to wash this stuff from your skin. Enjoy
                        Ed
                        • Chuck G.
                          • May 31, 1982
                          • 2034
                          Here's what I've used. Close to correct color too.
