1962 300 hp - Generator brush set? - NCRS Discussion Boards
  • David R.
    • June 29, 2014
    • 183
    Which is the correct brush set for my '62 300 hp? I have been offered several sets that "fit" and/or "will work" - but what set is factory correct? Thanks.
    • 43220
    Re: 1962 300 hp - Generator brush set?
    David-------
    Well, strictly speaking, the original brushes for your generator were GM #1906956. These are embossed '956'. However, these were discontinued in January, 1969 and replaced by GM #1932506, sometimes embossed '462'. The latter were available until quite recently when they were finally discontinued without supersession.
    You can also use Standard Motor Products #RX63. These are virtually identical to the original, will function PERFECTLY, and, believe me, no one will ever know they're not the 1906956.
    • Domenic T.
      • January 29, 2010
      • 2452
      David,
      I have just used what the dish out without any problems. Even put the brushes in my airplane generators. There are special brushes for high altitude airplanes and I think they have copper added. Any good auto parts should have good brushes. NOW the important part is cleaning the commutator and between the segments in the commutator.
      Dom
      • David R.
        • June 29, 2014
        • 183
        Thank you both. I knew that the RX63's were acceptable substitutes - I suppose I'll just go with those, and make sure I do a good clean-up job on the internals during the rebuild.
          • 43220
          Dave-------
          Attached are photos of the original GM #1906956 brushes [not for sale] used for your application. As I mentioned, these were discontinued in January, 1969 and replaced by the GM #1932506. Note that they are embossed '956'. However, other than the embossment that absolutely no one will ever see, I don't think you'll find them to be much different than the SMP RX63.
          • David R.
            • June 29, 2014
            • 183
            Many thanks, Joe - and others who responded as well. I knew I would get a "proper education" here on what's right, what's not, and what's available . . . and that's exactly what I got.
