73 Seatbelt Wiring Harness Questions? - NCRS Discussion Boards
  • Jimmy P.
    • June 24, 2014
    • 1695
    I'm in the process of replacing the aftermarket seatbelts in my 73 convertible. I've been in contact with Charlie Santorelli about getting the correct belts. My questions are about whether or not all the correct wiring is present. After removing my seats I found the wires/connectors shown in the attached photos below. The first picture is what was under the driver's seat. I assume it connects to the retractor on an original belt. The second photo is what was present under the passenger seat. The contact bar that clips to the metal seat supports under the passenger seat is also present. Looking in the AIM I see only one connection to the retractor on the driver's side. No buckle side wire? For the passenger seat, I saw the connection to the seat contact strip, but didn't see where that extra wire on the passenger side connected. I assume it must connect to the retractor to complete a circuit if someone is in the seat?
    Am I missing anything, or should I be good to go if I get the correct belts from Charlie?
    I appreciate any help, Thanks
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 73 Seatbelt Wiring Harness Questions?
    You should be good to go as long as the new old parts are in good working order.
    Lyle
    • Michael W.
      • April 1, 1997
      • 4290
      No electrical connection to the buckle (female) side is required. As the belt is pulled from the retractor, a switch opens turning off the buzzer and warning lamp.
      • Jimmy P.
        • June 24, 2014
        • 1695
        Lyle and Michael,
        Thank you both for responding. I guess I'm good to go. If I get the belts from Charlie, I'm sure they will be in perfect condition.
        Has anyone ever purchased seatbelts from David Sokolawski? He is out in Calif.and advertises in the Driveline too.
        Jimmy
        1973 Convertible
        L48,M20,N40
