61 270 hp fast idle - NCRS Discussion Boards
61 270 hp fast idle
  • John S.
    • May 4, 2008
    • 425
    61 270 hp fast idle
    I apologize in advance as I don't have any books or specs. Working on my bosses 61 270 hp car and I am having a hard time getting it to fast idle when it is cold and the chock is set. The choke on these cars is on the rear carb. Chock sets fine and there is a lvere that goes down to a small cam plate that the idle screw sets on. That all seems to function correctly. Problem is there is no fast idle. Problem seems to be the cam has no "cam" on it. Doesn't matter where the idle screw is setting on that cam it idles the same. Before anyone replies that the idle screw is not touching that plate I have already checked. It is definitely hitting the plate and when I make adjustments on the idle screw it does change the rpm's. Wondering if these plates wear out. Any ideas?
    John Seeley
    67 Black/Teal
    300 hp 3 speed coupe
    65 Maroon/Black
    35k mile Fuelie coupe
  • Frank D.
    • December 27, 2007
    • 2703
    Re: 61 270 hp fast idle
    Copy and past this link in your browser's address bar and you can find out all about WCFB carbs setup, maintenance, rebuilding and adjustment:
    Prob not the best idea to dink around with those dual quads unless you know what you are doing..
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11327
      It almost seems like a tab on the main lever is missing. I recall I had a WCFB once and the tab was broken off. My fast idle and choke on my 270hp setup has been working fine forever and I can't recall what it looks like off the top.
      Some close-up photos of the linkage on both sides may help figure out what may be wrong. And a good lookup of the details in the manuals will help for sure.
      Rich
      • Frank D.
        • December 27, 2007
        • 2703
        The manual in the link I posted Rich has pictorial drawings and close up photos.... They are as good as anything I could take with my camera in the garage. The OP should refer to that to figure things out....
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11327
          Yes that's a good reference. He should be able to figure it all out with that.
          I just found the tab on the lever I had on one that was missing. It's the tab for the fast idle cam. I've seen these broken and obviously needed for the fast idle to work. I just did a quick copy paste from that pdf to show it. It may not be relative to his issue, but your document helped me remember the piece I was thinking of.
          • John S.
            • May 4, 2008
            • 425
            Gents,
            The set up on the car I am working on looks different. Almost like this was for the early version and it changed by 61. I am going to take some pics and post so you can see.
            John Seeley
            67 Black/Teal
            65 Maroon/Black
            • Frank D.
              • December 27, 2007
              • 2703
              The car may have 'clone' carbs -- there are a ton of WCFBs of different makes repurposed for this use. If so, it may, or may not, have the correct parts/tabs/etc... Lots of owners are running clones and have no idea they aren't the 'real deal'...
              See if the carb lids have 6-1299 on both of them and then look down the primary nozzles and see if they are cut straight vertically like the secondary nozzles or at a 45* angle...
              • John S.
                • May 4, 2008
                • 425
                My bad. I was incorrect as the carb is exactly as shown. Tab is there also. One thing that I notice on both carbs is that the throttle shaft to the "linkage" part is loose. I think to loose. Have to put it on the back burner as I have PV stuff to work on with my 65.
                John Seeley
                67 Black/Teal
                65 Maroon/Black
