Carter AFB 3721SB carb - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1363
    Anyone know if this model AFB (Not sure if the "S" is an S or something else) has any Corvette applications? It's on a 340 hp '62; I know this is not correct carb for this application according to the judging manual.
  • Timothy B.
    • April 30, 1983
    • 5186
    Re: Carter AFB 3721SB carb
    Bill,
    I know it's the service replacement carburetor for 63-65 Corvette and probably (not 100%) the 62 model year with AFB carburetor.
    • Edward B.
      • March 29, 2013
      • 691
      Per CBTN, the Carter AFB 3721SB was used late 1965 model year on the full size, Chevelle and Corvette 327/300 with manual transmissions. The Chevrolet part number was 3851761.
      Ed
      • William F.
        • June 9, 2009
        • 1363
        Do you think jetting, etc. on this carb is suitable for functionality on a driver with 340 hp 327?
        • Jim D.
          • 2884
          What's the date stamped below the 3721SB? It could be an original for a 64-65 or a service replacement carb.
          • William F.
            • June 9, 2009
            • 1363
            Carb has I (or1) MO stamped just before and at same level as model number. Nothing stamped below model number. What does his mean?
            • Bob R.
              • June 30, 2002
              • 1595
              Can't tell from your explanation what the date is post a picture. A 3721 carb should work fine on a 340 horse engine.
              • William F.
                • June 9, 2009
                • 1363
                Those are the only things stamped on the front passenger side of carb base in a line, not one below the other. Will other stampings be found elsewhere on this carb?
                • Timothy B.
                  • April 30, 1983
                  • 5186
                  The only other ID is the aluminum tag if it's still there. They are good carburetors, don't be afraid to use it on your 340hp engine.
                  • Jim D.
                    • 2884
                    An original Corvette carb would be stamped as shown (this is March 65) and have the aluminum tag as well.
                    • Stuart F.
                      • August 31, 1996
                      • 4676
                      The 3721sb is a good compromise carb for use on any L-75 or L-76 62 thru 65 Vette engine. The jetting is good, but not ideal. If it runs good with no lean surge or hesitation I'd leave it alone. I run one on my 63 L-76 and leave my 3461s in a boxon the shelf. It is too valuable to leave on the car. My 3721sb is sweetened up a bit both in primary and secondaries, and I lightened the air valve weights to match my 3461s. The main difference for the 62 is the fuel inlet piping as it uses a glass bowel filter on a pipe stub.
                      Stu Fox
                      • William F.
                        • June 9, 2009
                        • 1363
                        Thanks to all
