Incorrect ECM part numbers - NCRS Discussion Boards
  • Kenneth P.
    • November 17, 2015
    • 151
    Re: Incorrect ECM part numbers
    Dave
    I'm pointing out that the part number they have listed is incorrect. If you or anyone can show me where to find 16153993 l would be more than happy to shut up. If I were to judge my car, by the book, I would loose points through no fault of my own. As for its "only a few points" well a few points here and there all add up and I don't like loosing any points especially when the book is wrong.
    Ken
    • Kenneth P.
      • November 17, 2015
      • 151
      Thank you for those words of wisdom!
      Ken
      • David H.
        • June 30, 2001
        • 1545
        #18
        Originally posted by Kenneth Peindl (61782)
        Dave
        Ken
        Ken,
        JMO but you will drive yourself nuts chasing minor point deductions. In-any-case, if the part actually is original, then at least at Regional/National meets you are not going to loose originality points. At Regional/National events the National Team Leader is present and will have updates to errors & additions to the current JG. If you have a particular question about your part number, then just contact the NTL and ask.
        I don't know the source of the xx993 part number. Perhaps it came off an original car used when the JG was under development. Perhaps it is a misprint. If you get a chance, be an Observer Judge on Chassis at a Regional or National - that will give you an opportunity to see the judging process in action with a NTL present.
        Dave
        • Ken A.
          • July 31, 1986
          • 929
          #19
          This is pretty simple: if the car starts & drives, the it has the correct ECM/PCM as well as the correct memcal.
          • Dick W.
            • 10483
            #20
            I sho' am glad I can't count past 3
            Dick Whittington
