Looking at New 9 Leaf Rear Springs. Are they both Correct? - NCRS Discussion Boards
  • Jason S.
    • January 2, 2012
    • 72
    #46
    Re: Looking at New 9 Leaf Rear Leaf SpringAre they both Correct?t?
    The Eaton Spring:
    • Jason S.
      • January 2, 2012
      • 72
      #47
      The John R Spring:
      • Gary B.
        • February 1, 1997
        • 7053
        #48
        Jason,
        If Mike at AFC can find an original '63 spring, then another possibility for you it to find one on your own and restorer it yourself, or use the top 3 leaves along with your '64 or newer take-off GM spring, which looks spot-on for a '64 and up spring. Frankly I'm shocked at the $695 price from AFC.
        Gary
        • Gary B.
          • February 1, 1997
          • 7053
          #49
          Jason,
          Original C2 springs did not come with those two bands around the 3 longest leaves. What's the label on the underside of the main leaf?
          Gary
            • 6950
            #50
            Jason, the top 3 leafs can be bend (need a press) to look like the other 63 springs, I have done this on 3 later springs and ride height was still perfect. And if you have a problem with the car sitting low with the original spring, try using the main leaf from the Eaton assy. have done this on one spring and worked again.
