Windshield channel preservative - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 675
    I've got three GM windshield channels (glass to frame gaskets) and they all have some kind of preservative on them. Kind of a waxy substance. Any suggestions on what to use to remove this prior to installing on the glass?
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11363
    Re: Windshield channel preservative
    Keith, Yes it's wax, the mold release.
    It's a real pain to remove. Soapy water does nothing, even with hot water.
    I use acetone on a terrycloth rag. The rag needs teeth. It's tedious but it works for me.
    • Keith R.
      • August 31, 2001
      • 675
      Thanks Richard. I was hoping that you would respond. I began installing the channel without removing the wax figuring that I could clean it up afterwards but it got all over the glass and was cleaning it up with lacquer thinner. I'm thinking that lacquer thinner is too aggressive to use on the rubber itself so I'll try the acetone. By the way, I presume that it is normal for the channel to spread out initially at the wing corners? Will fitting the frames and side posts compress this area in an acceptable manner?
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11363
        Yes as it turns the corners it'll open up a bit. I use masking tape to hold it in place while the sealer adheres to the rubber and the glass.
        Do you have my installation document?
        Rich
        • Keith R.
          • August 31, 2001
          • 675
          Thanks again Richard. I do have your installation document and am using it as a procedural guide - it is most excellent. I see that others have used masking tape to hold the rubber channel to the glass while installing it. That's a good tip particularly when you don't have a second set of hands.
          Keith MacRae
          NCRS #36692
          New Mexico Chapter
          1960 290HP FI
          • Wayne L.
            • September 30, 1981
            • 233
            Richard-
            Do you have a link to your installation document?
            Thanks, Wayne
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11363
              Originally posted by Wayne Loron (4921)
              Richard-
              Thanks, Wayne
              Wayne, Comcast deleted my website so I cannot supply a link. Send me a PM with your email address and I'll send you the pdf version.
              Rich
              • E B.
                • March 1, 1978
                • 126
                Keith, you may try using a heat gun on low to melt the wax then wipe off with clean shop towel. I used this method on tires. Ed
                • Gary B.
                  • February 1, 1997
                  • 7066
                  Rich
                  Rich,
                  I was so bummed when Comcast stopped allowing personal webpage. My monthly Comcast fee goes up yearly and my services go down.
                  Gary
                  • Keith R.
                    • August 31, 2001
                    • 675
                    Thanks E J. Good idea. I was thinking of warming it up with a heat gun anyhow before stretching it on the glass.
                    Keith MacRae
                    NCRS #36692
                    New Mexico Chapter
                    1960 290HP FI
