1970 headlight bezels - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 876
    Is the back of the metal bezel coated with zinc chromate or some other paint? I am preparing to paint a bezel that I purchased at a swap meet. It does not appear to be coated on the back.
  • Mark E.
    • April 1, 1993
    • 4548
    Re: 1970 headlight bezels
    I don't know if mine are original, but the backsides are unfinished pot metal (with body paint over spray).
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Stephen B.
      • April 1, 1988
      • 876
      Thanks Mark
        • 6942
        Steve, I seem to remember that my 72 had the green zinc chromate primer, most of the aluminum parts uses that primer.
        • Mark E.
          • April 1, 1993
          • 4548
          Are they aluminum?
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • John V.
            Infrequent User
            • February 5, 2014
            • 3
            Stephen,
            I'm new to the NCRS forum...but as I was searching for a post that a friend was going to do regarding a likely original coolant shut-off valve on my January (early build) 1970 350/300 w/A/C; Auto; 37,000mile NCRS TopFlight / Bloomington Gold Survivor...I stumbled across your post. I may be able to give you what you seek by examining the same headlight bezels on my original paint car. Are you concerned about what is behind the colored bezel (not visible side) surrounding the low/high beams?
              • 43221
              Are they aluminum?
              Mark------
              No, the bezels are zinc diecast material. At least, they were through 1972. After that year, they were plastic.
              • Stephen B.
                • April 1, 1988
                • 876
                I appreciate everyone's input.
                • Mark E.
                  • April 1, 1993
                  • 4548
                  Mark------
                  This made me wonder about Chevy's choice of materials. Diecast metal/ potmetal seems like an odd material to specify for this part. Fiberglass or plastic makes more sense. Lighter, less expensive and just as durable for this function.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                    • 43221
                    Mark------
                    As I previously mentioned, GM came to that conclusion for 1973 and later. But, for 1968-72, it was zinc diecast.
